Pimping A T-rex - Crank Advice Too
Phil H
I've got an Onza T-Rex. Basically im looking to upgrade it loads.
Im looking for a 'money no object' spec you reacon would be amazing.... (so I can dream)
And a Phil cheap man, but still good quality parts that will last.....(midrange kind of thing I guess)
Cheeeeers.
Phil
Edited by Phil_Onza
- Forks: Echo Urban '07
- Front hub: Chris King ISO or Hope Pro 2
- Rear hub: Chris King Singlespeed HD
- Head set: Chris King
- Crank: Adamant or Middleburn
- Bashring: 74Kingz + 18t cog
- Front brake: Hope Mono Trial 180 '07
- Rear brake: Magura HS33
- Front rim: Echo 2006
- Back rim: Echo 2007
- Spokes: Sapim Race DB
- Front tyre: Maxxis High Roller 2.35
- Back tyre: Maxxis Minion dual ply 2.5
- Stem: Thompson
- Grips: Whatever
- Handlebars: Pazzaz/Onza 30" carbons
- Chain: KHE collapse
- Rear Sprocket: King Kog 15/16t
- Tensioner: Rohloff
- Bottom bracket: SKF
- Pedals: Onza Hognesium
I'll do a cheap one tomorrow, I'm too tired to think properly atm...
- Forks: Echo Urban '07 or smart guys
- Front hub: hope xc/onza/anything with decent bearings
- Rear hub: pro II trials
- Head set: FSA internal, mines well nice
- Crank: Middleburn
- Bashring: Burns ring
- Front brake: Avid SD7
- Stem: Echo control/Hi-Fi
- Grips: Whatever
- Handlebars: Zoo's
- Chain: KMC Kool
- Rear Sprocket: Surley single speed
- Tensioner: rear mech
Just one problem with yours shaun, t-rex frame takes an internal/integrated headset thing so a king wouldn't fit.
Right cranks are bent - need some new ones.
At the moment Ive got a square taper BB and about £70.
What you think? I was thinking of 2nd hand burns...(would be lucky for ^ that kind of money)
Phil
ebay for crank arms, square taper arms usually go for around £40-50 with only xc/dh use so no trials scratches. Then you can pick up a bash/chainring off here for cheap.
Hmm yeh Im well up for getting some just through someone on TF. Do you ride truativs? (or do my eyes decieve me)
I'll have a hunt around for some bargain burns. Not sure whether to get Isis, meaning I have to replace the BB, however might be better in the long run.
Phil
- Head set: Hope
- Crank: Adamant
- Stem: Echo Hifi
- Grips: Whatever
- Tensioner: Fresh Products
Few changes....
