eskimo Posted November 15, 2006 Report Share Posted November 15, 2006 Snapped disc mounts on frame?What do you guys think? Surely this WILL affect the strength the bike has left. I'm considering bidding.http://cgi.ebay.co.uk/TOXSIN-ONE-TRIALS-BI...1QQcmdZViewItem Quote Link to comment Share on other sites More sharing options...
roly Posted November 15, 2006 Report Share Posted November 15, 2006 Its a tricky one> I reckon you might get a good deal there but I would definitely find out how it happened. The pics don't show it too clearly but I reckon you'll be ok. The stress from rim braking should be far enough up the dropouts not too be a problem. Quote Link to comment Share on other sites More sharing options...
the judge Posted November 15, 2006 Report Share Posted November 15, 2006 I don't think it'll make any difference at all, as the bit that has snapped off isn't usually there at all on most trials frames. Quote Link to comment Share on other sites More sharing options...
Ducko Posted November 15, 2006 Report Share Posted November 15, 2006 frame will be fine! it wont effect the strength as the pressure is put on the snapped part not any other part of the frame! Quote Link to comment Share on other sites More sharing options...
Shaun H Posted November 15, 2006 Report Share Posted November 15, 2006 There's no question that disc brake usage has stressed the frame to some degree though Nick. I was thinking of bidding on that but obviously can't now.... Quote Link to comment Share on other sites More sharing options...
T-BAD Posted November 15, 2006 Report Share Posted November 15, 2006 be reet, just get him to email you a pic of the snappage then post it up on here we all get a clear view then Quote Link to comment Share on other sites More sharing options...
Ducko Posted November 15, 2006 Report Share Posted November 15, 2006 the pressures on the frame wqould have been from when the disk was used just like any other rear disk frame there will be stress down the seat stay when breaking, but the part that has snapped has failed because that part was not strong enough not that the frame as a whole was not strong enough. underengineered mounts. Quote Link to comment Share on other sites More sharing options...
Guest Posted November 15, 2006 Report Share Posted November 15, 2006 the pressures on the frame wqould have been from when the disk was used just like any other rear disk frame there will be stress down the seat stay when breaking, but the part that has snapped has failed because that part was not strong enough not that the frame as a whole was not strong enough. underengineered mounts. Or over engineered in that they were too stiff and didn't allow any flex. Quote Link to comment Share on other sites More sharing options...
Shaun H Posted November 15, 2006 Report Share Posted November 15, 2006 Toxsins usually crack at the headtube don't they? (if at all)I say go for it Nick. Quote Link to comment Share on other sites More sharing options...
Greetings Posted November 15, 2006 Report Share Posted November 15, 2006 It'll be fine. The disc mount on these frames is very weak and you don't need much force to brake it off. Go for it Quote Link to comment Share on other sites More sharing options...
The Next Steve Peat Posted November 16, 2006 Report Share Posted November 16, 2006 The mech hanger looks bent to me Or am I seeing things? Quote Link to comment Share on other sites More sharing options...
