Rear Or Front Freewheel?
Spider_JJ
i think if you have a cassette hub you should use one of them instead of a freewheel because they blow up and you dont want that when your doing something especially when your going to do things in london.
How can freewheels blow up?? Cassette hubs can also then, even sooner than (for example) ACS freewheel.
Money no problem, buy a rear Pro2 and get some decent cranks e.g Tensiles or Middleburn.
Monday is a problem, buy a rear XC or dmr revolver hub and 16t acs then buy Tensiles.
You will always need a decent set of cranks really as they're the part that takes a battering so don't skimp out when buying them.
pro 2 with tensiles, or if you have lots of money middleburn cranks.
if you want a few more engagements get the ENO freewheel with tensile cranks on the front and have a echo fixed hub on the back.
If you ride stock though dont get a freewheel.go for the pro 2.
EDIT: dont listen to the above.Just get a pro 2 :)
max...
Edited by max-t
