coolbeen Posted November 12, 2006 Report Share Posted November 12, 2006 I am just asking how do you like your gearing. Do you like it when it is easy to kick or when it is hard a bit to kick. Because I had 22:18 and that was hard then I tried 18:16 and that was really easy to kick, so how do you like it. Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted November 12, 2006 Report Share Posted November 12, 2006 i'm running mine at 18:16 at the moment because i got a ffw ,but i was running it at 15:13/12 with a normal hub it all depends on whats right for you mate,experiment .a word of warning ,try searching before you make topics ,folk get annoyed about these things . Quote Link to comment Share on other sites More sharing options...
coolbeen Posted November 12, 2006 Author Report Share Posted November 12, 2006 i'm running mine at 18:16 at the moment because i got a ffw ,but i was running it at 15:13/12 with a normal hub it all depends on whats right for you mate,experiment .a word of warning ,try searching before you make topics ,folk get annoyed about these things .I have mate but this is about do people like a hard kick from the gears or an easy kick. Quote Link to comment Share on other sites More sharing options...
a to b in style Posted November 12, 2006 Report Share Posted November 12, 2006 18:16 is the best mate u cant go wrong with that trust me Quote Link to comment Share on other sites More sharing options...
coolbeen Posted November 12, 2006 Author Report Share Posted November 12, 2006 Come on guys i need more help. I run 22,18 that was really hard and made the bike feel really haevy. Then i went to 18.16 and that was to easy and the kicking was to easy to do. So i was think about 20.16 what do you lot think. I am running 170 cranks. Quote Link to comment Share on other sites More sharing options...
RobinJI Posted November 12, 2006 Report Share Posted November 12, 2006 20:16 will be harder than 22:18The way to work it out is to divide the front sprocket by the rear sprocket, i.e. 22/18=1.222The higher the number the harder it will be to kick, 20:16 would be 20/16=1.25 wich is harder than 1.222Your current geering is 18/16=1.125So you want a number between 1.125 and 1.222A few examples of geering you could run:18/15=1.220/17=1.17616/14=1.142 Quote Link to comment Share on other sites More sharing options...
coolbeen Posted November 13, 2006 Author Report Share Posted November 13, 2006 20:16 will be harder than 22:18The way to work it out is to divide the front sprocket by the rear sprocket, i.e. 22/18=1.222The higher the number the harder it will be to kick, 20:16 would be 20/16=1.25 wich is harder than 1.222Your current geering is 18/16=1.125So you want a number between 1.125 and 1.222A few examples of geering you could run:18/15=1.220/17=1.17616/14=1.142Thanks mate for the help I will just keep with the 18:16 I think so i don't have to buy new stuff. Quote Link to comment Share on other sites More sharing options...
kid creole Posted November 13, 2006 Report Share Posted November 13, 2006 does engagement points effect how stiff the gearing feels ? because i have a try-all freewheel and the same gear ratio I'm used to 18:14 feels stiffer now all thou i have had 18;16 for a short time in between so it could be i got used to that but i remember 18:14 being lighter before i had this freewheel. Quote Link to comment Share on other sites More sharing options...
