Dan Jones Posted November 9, 2006 Report Share Posted November 9, 2006 I'm looking at the ISIS SKF bottom bracket with an axle length of 128mm.I would like to find out if this will give more chain ring clearance (against frame),when compared to a 127.5mm UN52 square taper (assuming the taper is in good condition).Thanks.With my current set up the 22t chain ring is almost touching the frame. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted November 9, 2006 Report Share Posted November 9, 2006 It greatly depends how old/worn the tapers are on the square cranks...Which exact setups are you comparing? Let me know and I'll do some measuring for you...CheersAds Quote Link to comment Share on other sites More sharing options...
GlynnP Posted November 9, 2006 Report Share Posted November 9, 2006 (edited) beat me to it Edited November 9, 2006 by RealRiding Quote Link to comment Share on other sites More sharing options...
Dan Jones Posted November 9, 2006 Author Report Share Posted November 9, 2006 When the taper was new it was a close fit. My bike is a Triton Deema and its designed to be used with a FFW.I'm using Middleburn RS7 pro trials cranks with a 22t chain ring.Thanks! Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted November 9, 2006 Report Share Posted November 9, 2006 Another one, sorry... whats the BB shell width on that frame?Cheers! Quote Link to comment Share on other sites More sharing options...
Dan Jones Posted November 9, 2006 Author Report Share Posted November 9, 2006 its a 68mm shell,thanks Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted November 9, 2006 Report Share Posted November 9, 2006 Well, it appears there's really not a lot in it... As both the setups are designed to give the same chain line when fitted with a 'normal' chainset.One thing we do have though is an Onza Taper BB in 127.5mm with an offset axle - this offsets everything approx 2mm to the drive side. This will give you more chainring clearance Give me a shout if that would be of use to you.CheersAdam Quote Link to comment Share on other sites More sharing options...
