1337 Trials Posted November 8, 2006 Report Share Posted November 8, 2006 Hey. What is a good disc for a mod trials bike and what is a good size ??? ~Matty Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted November 8, 2006 Report Share Posted November 8, 2006 are you after a front or rear brake?there was a person who posted up the effect of different sized rotor on different wheel sizes , try the search to find it mate Quote Link to comment Share on other sites More sharing options...
1337 Trials Posted November 8, 2006 Author Report Share Posted November 8, 2006 Front You mean this.........? http://www.trials-forum.co.uk/forum/index....showtopic=86249 ~Matty Quote Link to comment Share on other sites More sharing options...
Tom Perkins Posted November 8, 2006 Report Share Posted November 8, 2006 Try a Hope mono trials 180. My mates is brill. Quote Link to comment Share on other sites More sharing options...
1337 Trials Posted November 8, 2006 Author Report Share Posted November 8, 2006 You sure about the 180 as it is a mod. Also what is the feel like??? Sharp bite etc??? P.s. Thanks for your advice ~Matty Quote Link to comment Share on other sites More sharing options...
Tom Perkins Posted November 8, 2006 Report Share Posted November 8, 2006 Well my mate sidehops right so he doesnt catch it. He wamted the 180 for some extra power. It locks and bites really well and holds on the most weird conditions. Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted November 8, 2006 Report Share Posted November 8, 2006 I use a Mono trial 180mm and it's mental, once it's gotten a little heat into it, she become very powerfull! Quote Link to comment Share on other sites More sharing options...
BrickTop Posted November 8, 2006 Report Share Posted November 8, 2006 Try Magura Loise 203". Quote Link to comment Share on other sites More sharing options...
1337 Trials Posted November 8, 2006 Author Report Share Posted November 8, 2006 Awsome. I WANT ONE!!! With xmas comming up I have a hope xc hub in the bike shop so ile get that built onto my old dx-32 rim. Be like £50 max then ile get a 180 rotor hope mono trials. Sound good? P.s. I sidehop to the right so ile be ok ~Matty Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted November 8, 2006 Report Share Posted November 8, 2006 I go to the right as well!Ie: my drive side is the way i got (my right) Quote Link to comment Share on other sites More sharing options...
1337 Trials Posted November 8, 2006 Author Report Share Posted November 8, 2006 Arn't hope mono trials hard to setup or something like that. If there not 100% set up then dont work??? ~Matty Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted November 8, 2006 Report Share Posted November 8, 2006 (edited) In erm 10 years + of using hopes i've never hered that one!Echo Hi-fi forks need facing as do the teams.Hope dead easy to set up as is any otherFit the discFit the wheelLosely with no shims put the bolt on through the forks and into the claiper a few turnsFit the leaverPump the system so the claiper centrals it's selfGet you mum, dad, sister, bro, g/f, m8, cable tie to hold the leaver backNow fit the shims where need on the inside and do the bolts upLet the leaver goCheck it doesn;t runAdjust with shims as needs beTweak the leaver reach as diseredGo get it wet and ride to bed it inOh and do you not use your msn account at all what so ever? Edited November 8, 2006 by Wright Pads Quote Link to comment Share on other sites More sharing options...
1337 Trials Posted November 8, 2006 Author Report Share Posted November 8, 2006 Thanks mate ile probarley get my lbs to do it because ile get my wheel built there with the xc hub. Does anyone know anywere that do hope mono trials 180mm rotors cheaper than £140 (Tartybikes is £140) ~Matty Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted November 8, 2006 Report Share Posted November 8, 2006 (edited) Do you not see my last message?Go log on to your msn account or update you profile with the correct addyahem Edited November 8, 2006 by Wright Pads Quote Link to comment Share on other sites More sharing options...
TOBY E Posted November 8, 2006 Report Share Posted November 8, 2006 i run a front hope mono mini trial with 180 rota works brilliantly no problems at all worth the money Quote Link to comment Share on other sites More sharing options...
adamtrials Posted November 8, 2006 Report Share Posted November 8, 2006 Get an avid bb7, much cheaper than hope, as powerful if not more so, easy to set up and more reliable. Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted November 8, 2006 Report Share Posted November 8, 2006 Unless your AlexT and lose the pin...god knows how! Quote Link to comment Share on other sites More sharing options...
monty kid Posted November 8, 2006 Report Share Posted November 8, 2006 I run a maggie marta 160 and bits like hell!!and are cheaper than a hope Quote Link to comment Share on other sites More sharing options...
Orgun_Donor Posted November 8, 2006 Report Share Posted November 8, 2006 My hope mono trial 180mm was good... till it poped. Now my Magura Julie,is the shizzle! Quote Link to comment Share on other sites More sharing options...
1337 Trials Posted November 8, 2006 Author Report Share Posted November 8, 2006 Hehe. Im confused what to go for. A mono trials seems best as its made specialy for trials and comes in a set rather than a bb7. How did your hope pop??? ~Matty Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted November 8, 2006 Report Share Posted November 8, 2006 Comes in a set? Quote Link to comment Share on other sites More sharing options...
1337 Trials Posted November 8, 2006 Author Report Share Posted November 8, 2006 Comes as one should I say. The avid bb7, you have to buy lever and cable ~Matty Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted November 8, 2006 Report Share Posted November 8, 2006 Hydrolic discs will never be this and that!Avid work yeah, but i find Hope work a lot better!It's more of weight thing Quote Link to comment Share on other sites More sharing options...
1337 Trials Posted November 8, 2006 Author Report Share Posted November 8, 2006 Is a hope better for bigger built people??? P.s. Im Big and phat ~MattyOne thing I forgot to ask, looking at the hope mono mini and the hope mono trials they look the same apart from a silver cap on the caliper for the mono trials and gold on the hope mono mini. What is the difference??? P.s. What makes one better than the other ~matty Quote Link to comment Share on other sites More sharing options...
Dr Dig Posted November 8, 2006 Report Share Posted November 8, 2006 from tarty bikes: Upgraded' hydraulic piston ratios gives 54% more mechanical advantage and thus far more power than any standard disc brake featuring a similar sized rotori tihkn they're just stronger Quote Link to comment Share on other sites More sharing options...
