T-OM Posted November 7, 2006 Report Share Posted November 7, 2006 I have a t-mag and was wondering if it is possible to drill holes for snail cams on my frame. Quote Link to comment Share on other sites More sharing options...
Tylerlovesalex Posted November 7, 2006 Report Share Posted November 7, 2006 hi mate yea you could do but i would of thought it would weaken your frame i don't think there would be any point in the hassle just use chain tensioners cheers tyler. Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted November 7, 2006 Report Share Posted November 7, 2006 you could do it, it wouldn't weaken the frame much at all but you would need to get the holes tapered if you do it let us know how it goes thanks adam Quote Link to comment Share on other sites More sharing options...
Barbra Posted November 7, 2006 Report Share Posted November 7, 2006 ive been thinking about cams as well, if i knew where to drill the hole on my frame then i'd do it, taper them and use them. Gosh, don't chain tugs suck. If someone could shed some light onto where i should drill my holes that would be cool? Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted November 7, 2006 Report Share Posted November 7, 2006 ive been thinking about cams as well, if i knew where to drill the hole on my frame then i'd do it, taper them and use them. Gosh, don't chain tugs suck. If someone could shed some light onto where i should drill my holes that would be cool? if you go on ebay search trials and theres a monty frame on there with a close up pic of the drop outs, from that pic you should have a good idea of where to drill. hope this helps Quote Link to comment Share on other sites More sharing options...
T-OM Posted November 7, 2006 Author Report Share Posted November 7, 2006 I may stick with chain tensioners anyone no where i can get a good set. i have crappy onza chain tugs at the moment. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted November 7, 2006 Report Share Posted November 7, 2006 How do snail cams weaken the frame? Quote Link to comment Share on other sites More sharing options...
ted Posted November 7, 2006 Report Share Posted November 7, 2006 How do snail cams weaken the frame? Its drilling the holes in your frame that weakens it. Quote Link to comment Share on other sites More sharing options...
mrBENN Posted November 7, 2006 Report Share Posted November 7, 2006 (edited) Hey there my friend has the same problem and wonts to run cams and he did what your suggesting to do and it worked fine and you can get the cam bolts from tarty but year he did it on a t-mag frame and didn't weaken it at all and its still goin strong so tell us how it goes if you do it. Edited November 7, 2006 by ..ben.. Quote Link to comment Share on other sites More sharing options...
matt! Posted November 7, 2006 Report Share Posted November 7, 2006 waste of time, IMO may aswel just use normal chain tugs.... Quote Link to comment Share on other sites More sharing options...
Tylerlovesalex Posted November 7, 2006 Report Share Posted November 7, 2006 what are so good about cams??? Quote Link to comment Share on other sites More sharing options...
Joey B Posted November 7, 2006 Report Share Posted November 7, 2006 I agree that the ONZA chain tugs suck ass. but if you are determined to stay with chain tugs go for some of the profile ones LINKY>>> Quote Link to comment Share on other sites More sharing options...
