Tpa Adjuster Wheel Has Seized
minipeg
When i bought my bike second hand, both tpa's had seized. I used a screwdriver and a hammer to gently nudge the tpa around a bit each hit. It takes a while but if you unwind it completely and then remove the lever from the handle, you can clean the internals and then grease 'em up good to prevent it happening again.
