Wow
theres nothing wrong with the bb.its from supercycles (onza)
they allways sell them cheap.
This is an absolutley BRAND NEW frame straight from our stock room!
The bottom bracket-shell-thread is cut slightly bigger than a standard BB shell to take an oversize Square taper bottom bracket, this is included with the frame as shown in the pictures, and is the same size used in complete T-Pro bikes, so there shouldn't be any problem fitting square taper compatible trials cranks.
So there is something wrong with it... :P
But surely you could just screw any BB in there? :ermm:
Edited by Dan6061
shhhhhhhhh, he doesnt know that..anyway it doesnt matter because the bb comes with it.the frame will probably snap before the bottom bracket does.no offence.
Edited by max-t
The T-Pro geometry is virtually identical to one of the Koxx Levelboss mods, and I thought they carried over the geometry from the Levelbosses to the XTPs?
Either way, you can't get a regular BB in those frames. I had one that was over-sized, and when I tried putting a normal BB in, it just kept coming loose no matter what you did to it, and stripped the threads...
