trials wannabe Posted November 1, 2006 Report Share Posted November 1, 2006 (edited) hi a few pepole told me that if i leave my bike out in the cold the brakes with freeze up but is that true will they freeze if i leave them in my shed through the winter cmon plzzz i need help Edited November 1, 2006 by trials wannabe Quote Link to comment Share on other sites More sharing options...
Simpson Posted November 1, 2006 Report Share Posted November 1, 2006 if you are running just water then yes there is a chance of the brakes freezing and because the brake doesnt have a resevior when the water expands in the hosing it CAN cause the hosing to crack. In a shed yes i would worry if my brakes were bled with water..... but in most bricked garages they should be ok - my friend complained about his brakes freezing up on late night rides...easyiest solution is to re-bleed through with water mixed about half and half with anti freeze which lowers the freezing point of the water in your hosing.... means your brakes wont freeze and also because its about the same viscosity your lever pull and the way it reacts will be very similar to just pure water Quote Link to comment Share on other sites More sharing options...
ted Posted November 1, 2006 Report Share Posted November 1, 2006 If you have water in the brakes it will. But if you are using oil in them then i think it would be ok Quote Link to comment Share on other sites More sharing options...
trials wannabe Posted November 1, 2006 Author Report Share Posted November 1, 2006 umm what if i used the magura blood oil ? Quote Link to comment Share on other sites More sharing options...
Simpson Posted November 1, 2006 Report Share Posted November 1, 2006 its fine 100% no need to worry Quote Link to comment Share on other sites More sharing options...
samo Posted November 3, 2006 Report Share Posted November 3, 2006 they shouldn't do if you are using oil but if u bleed them with water put some anti freez in Quote Link to comment Share on other sites More sharing options...
Rich Pearson Posted November 3, 2006 Report Share Posted November 3, 2006 If you have water in the brakes it will. But if you are using oil in them then i think it would be ok Unless the temperature drops to about -80C. Then your screwed. Rich Quote Link to comment Share on other sites More sharing options...
