bionicman Posted October 30, 2006 Report Share Posted October 30, 2006 i was wondering if i brought a 26" gu typhoon would the tyre rub on the frame with a 2.5 tyre and a try-all wheel because my mate uses a 20" gu and he has the problem of the tyre rubbing on the frame with the same rim but try-all tyredoes any one no if it will fit Quote Link to comment Share on other sites More sharing options...
ZHI-sam Posted October 30, 2006 Report Share Posted October 30, 2006 i was wondering if i brought a 26" gu typhoon would the tyre rub on the frame with a 2.5 tyre and a try-all wheel because my mate uses a 20" gu and he has the problem of the tyre rubbing on the frame with the same rim but try-all tyredoes any one no if it will fit im not 100% sure but i think not, ive heard that you have a real problem getting them in.best thing to do is talk to a few of the guys here who ride them. will edit with links to people when i find them Quote Link to comment Share on other sites More sharing options...
N.Wood Posted October 30, 2006 Report Share Posted October 30, 2006 Depends on make of tyre. Some are fatter than others. Go for a Maxxis 2.35/Michelin 2.2 and you'll be sorted. Quote Link to comment Share on other sites More sharing options...
ZHI-sam Posted October 30, 2006 Report Share Posted October 30, 2006 i was wondering if i brought a 26" gu typhoon would the tyre rub on the frame with a 2.5 tyre and a try-all wheel because my mate uses a 20" gu and he has the problem of the tyre rubbing on the frame with the same rim but try-all tyredoes any one no if it will fit Quote Link to comment Share on other sites More sharing options...
N.Wood Posted October 30, 2006 Report Share Posted October 30, 2006 Yeh, so it says Try-All wheel. So we've determined that he's using a 47mm wide rim. Grand.Not all 2.5" tyres are the same. I've got 2.4" tyres that are thinner than 2.2" tyres.So I'm asking what tyre he intends on running. Quote Link to comment Share on other sites More sharing options...
dan more Posted October 30, 2006 Report Share Posted October 30, 2006 as long as youve got the right tension you should be fine thats what happened with my gu if not center the wheel if youve gota stock dan Quote Link to comment Share on other sites More sharing options...
La Bourde Posted October 30, 2006 Report Share Posted October 30, 2006 Get the ERTRO's size (European Tyre and Rim Technical Organisation).It's a standard describing the width of a tire.It' a label wrote on the tyres like xx- 559, where xx is the width in millimeter.559 means 26".Then you measure tire clearance on your bike. Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted October 30, 2006 Report Share Posted October 30, 2006 Look here...use the search Quote Link to comment Share on other sites More sharing options...
