Andrex Posted October 27, 2006 Report Share Posted October 27, 2006 My cranks will no stop wobbling and creaking I've tightened the bolt for the cranks and tightened the bottom bracket and it still wobbles. Anyone got any ideas in what it might be? Quote Link to comment Share on other sites More sharing options...
Orgun_Donor Posted October 27, 2006 Report Share Posted October 27, 2006 The bearings in your BB.Mine are on their way out, and my cranks are creaking and wobbling because of it. Quote Link to comment Share on other sites More sharing options...
Andrex Posted October 27, 2006 Author Report Share Posted October 27, 2006 It's only just all of a sudden started happening after I put my new cranks on, do barings die that quick? Quote Link to comment Share on other sites More sharing options...
Broomer Posted October 27, 2006 Report Share Posted October 27, 2006 (edited) you should of noticed the bb bearings getting worse and worse over time.hold the crank arm and wobble it and can you see the axel moving too, if soo your bb has gone. Edited October 27, 2006 by Broomer Quote Link to comment Share on other sites More sharing options...
bionicman Posted October 31, 2006 Report Share Posted October 31, 2006 go and buy a new bb and see if that does the job Quote Link to comment Share on other sites More sharing options...
monkeymoped Posted October 31, 2006 Report Share Posted October 31, 2006 easier to just buy a new bb Quote Link to comment Share on other sites More sharing options...
max-t Posted October 31, 2006 Report Share Posted October 31, 2006 either that or your crank tapers have rounded off.max... Quote Link to comment Share on other sites More sharing options...
Andrex Posted October 31, 2006 Author Report Share Posted October 31, 2006 Well to be honest buying a new bb would make a hell of allot of sense. Cheers for everyones help Quote Link to comment Share on other sites More sharing options...
maxxis26 Posted November 2, 2006 Report Share Posted November 2, 2006 (edited) heres a quick diy bodge if your cranks a roundedcut up and old plasic bottle and snip them in to slides and put them in side the square tapers of your cranks and whack the cranks back on and do the bolt upit will hold very tight and will last about a month have done it before and can keep you riding till you can get new cranks Edited November 2, 2006 by maxxis26 Quote Link to comment Share on other sites More sharing options...
luke_onza Posted November 2, 2006 Report Share Posted November 2, 2006 My t-master crank is doing it and I carnet find out what it is, I have taken it all apart and there doesn’t seem to be anything amateur with it. It is like a multi spine bb. When I put a lot of weight on it, it jolts like 1milimeter. Any body know what it may be? luke Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted November 2, 2006 Report Share Posted November 2, 2006 Cheap cranks, the taper has rounded off. Also cheap BB it can be!Coke, beer can cut up does the job.Also heps if you don;t ride when you cranks come lose! Quote Link to comment Share on other sites More sharing options...
luke_onza Posted November 2, 2006 Report Share Posted November 2, 2006 Cheap cranks, the taper has rounded off. Also cheap BB it can be!Coke, beer can cut up does the job.Also heps if you don;t ride when you cranks come lose!Pete is that a tip for me? or is it for Andy? Luke Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted November 2, 2006 Report Share Posted November 2, 2006 Any one thats wakes up and notice they have lose cranks due to not looking after there bike correctly Quote Link to comment Share on other sites More sharing options...
max-t Posted November 2, 2006 Report Share Posted November 2, 2006 the way around it is to take an 8 mil spanner out with you and then if they come loose then you can tighten them up.also, its a good idea to check that all of your threaded parts are nice and tight before you ride every day and if need be add a bit of lock tite to keep them secure.max... Quote Link to comment Share on other sites More sharing options...
Andrex Posted November 2, 2006 Author Report Share Posted November 2, 2006 Any one thats wakes up and notice they have lose cranks due to not looking after there bike correctlyare you trying to say i don't know how to look after my bike? cheers everyone else for your tips and by the way its an isis bb. Quote Link to comment Share on other sites More sharing options...
Louth Trials Posted November 2, 2006 Report Share Posted November 2, 2006 It could be your bottom bracket mate, i would go and get a decent new one. Is it the axelthat is wobbling, if it is i would definetly get a new bottom bracket. If its your crank that is rounded i tryed all sorts of materials, to put in but the crank eats it! (not literally!) I know a few people thathave put coke can in, and i have put copper in, i have done this as copper is softer than aluminium and won't damage it further... Quote Link to comment Share on other sites More sharing options...
