Magura Julie
Sucram
The standard plastic levers are a bit flexy but overall the brake is good for the money (on the front wheel). I attached mine to my old front hs33 lever and bled with thin mineral oil. This gave me a pretty decent brake with loads of hold and good feel plus I had an adjustable bite point because of the hs33s TPA.
I have a julie on the front of mine at the moment, not as much bite as a hope, but the hold is just as good. I found the build of the julie to be far supriour to the Mono Trial, which flexes like mad, at both the caliper and the lever, where as even after several months, my julie is fer stiffer, infact wh i got it, it was far to stiff, and it started to hurt my finger.
Julie = (Y)
Hope = :(
