Removing My Fixed Cog
You need a vice and a old chain, wrap the chain round the cog so no teeth are showing then clamp it tight in the vice. Get a scafold tube or something along the lines that will slide onto the crank arm for more leverage and then just pull hard. If it slips in the vice do it up more ... should come of, Mine did with ease.
Good luck.
