Help With College Work
Johneh
Ive been asked to explain a cars starting system for a piece of college work, what I want to know is;
What does a cars starting system consist of, is it just the ignition switch, starting solenoid, and starter motor etc, or is the distrobutor and spark plugs etc involved, or is this part of a different system, the ignition system.
Thanks in advance for any help you give me :)
Edited by Johneh
Coil, distributer, plug/HT leads, etc, are part of the ignition system I would have said. They're used all the time the engine is running.
The starting system I assume are those parts that are only used during starting, i.e. the parts you mentioned 'ignition switch, starting solenoid, and starter motor'.
