Rear Disc Help Wanted
watto
Does any mod rear disc hub fit on a monty221pr frame allowing a disc to be without any dodgy adaptors or such ?
I await replys, Many thanks
Adam.
I'm sure it will if you can find one.
I've never seen a seperate mod disk hub for sale before.
EDIT: i stand corrected, just saw that monty one on tarty :$
Edited by ted
Im sure it will if you can find one. :-
I've never seen a hub for mods with rotor bolts.
Monty 221ti hub. Only one I've seen though. Should fit a 221pr.
Edit: Oh yeah, any mod hub should in theory, its just the Kings with ISO body's on them that screw things up as far as I know, as the BMX hubs axle spacing is different, so puts the disc spacing out. (correct me if I'm wrong)
Edited by Dont you Just Hate it When...
Yeah thats why i was asking, because i dont want to just get a monty hub if there is a rear freehub disc compatible, due to my hatred of front freewheel.
Maybe we need to visit the house of deng and give him ideas.
Edited by watto
As it was said before, the Ti hub is the only hub which will fit the PR frame without having to bend it. Running a wider hub will end up with the chainstays cracking after a longer period of time. I think that Profile have got their disc spacing wrong, the same applies to BMX King hubs fitted with an ISO Disc hubshell. So you can either get a freehub and risk cracking the frame, or buy a front freewheel. Go for a freehub.
yeh i ride a freehub in the rear on my monty 221 ti only for 1 day but its still okay not broken yet :lol: . i don't ride a monty hub because the just to have only 2 barings in them and you only can get them from monty because the are a f**ked up size, i looked every where and couldnt find 1. and why i don't ride a freewheel in the front is because i f**ked up 3 hubs with treat on them, my last hub lived for 5 days and was a try all hub so i bought myself a profile mini. :D:D:D:D:D:D:D
