Help With Balancing On Back Wheel
danfox23
There is only one thing for it if you want to get better; you have have to go out alot and ride.The same principles apply with anything you want to get good at it just takes alot of practice as you start to improve the rest such as your balance and technique should follow. If you are finding it hard to learn certian techniques and find the internet is of no use you could always try riding with other people which will give you the insperation to improve and they may be able to give you better tips on how to do stuff. Also you shoudl start leanring with what ever feels most comfortable for you we all have our own ways of doing things.
Edited by minicrack
no , but it will give you more surface area on your tyre so its easier to balance. And letting it down by about 15psi wouldnt make a mega difference, but it will help. You wont hit your rim unless you bounce on a corner of a wall or something, if you let it down about the right amount. Dont make it so the weight of your bike makes the tyre shrink. :ermm::D
