Steam And Css Problem, Computer Restarts When Loading Css
Ingram
hello, i was helpin gmy mate use his css using steam, but for some reason it locks up and restarts the computer when you try and load the game up, has anyon else experienced this problem if so how did they fix it?! Thanks alot for your help. :)
[attachmentid=7740]
Make sure you have automatic restart switched off (shown in the pic) because then you can see what the error is when it crashes. Could be something to do with the version of his graphics card or other things. Just make sure everything is updated and try again.
Maybe re-install or re-download the game off steam as well.
Do you have a shut down tempreture? Anymore details, computer spec? Cooling method?
More than likely it'll be a driver issue though. Do you actually begin playing? Or does it shut down the second you open it?
Lastly, before restarting, do you get a blue screen with some white text for just a split second?
