ketchup Posted October 23, 2006 Report Share Posted October 23, 2006 hey i would like to know what brakes are better for trials riding? Hydraulic - rim - disci am not too sure about this but i heard you can get hydraulic v- brakes? Quote Link to comment Share on other sites More sharing options...
Dr Dig Posted October 23, 2006 Report Share Posted October 23, 2006 (edited) hi,most people have a disk brake on the front and run a magura (hydraulic rim brake) on the back. for info on these brakes id suggest going onto tartybikes.co.uk they have a wee explination of the brakes Edited October 23, 2006 by cal d Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted October 23, 2006 Report Share Posted October 23, 2006 Personal preferance.I run a 160mm Avid BB7 up front on my Zona. - Mechanical disc brake.And a Magura HS33, Plaz pads on the back. - Hydraulic rim brake.Ali C will tell you to get a V. - Avid Ultimate..Becuase he prefers them compared to a Magura. Quote Link to comment Share on other sites More sharing options...
bennyb Posted October 23, 2006 Report Share Posted October 23, 2006 Well i run a front disc on the front and a hs33 magura brake on the rear .....for more info ....go to www.tartybikes.co.uk like ...( cal d ) sed ...thanks bennyb Quote Link to comment Share on other sites More sharing options...
Ali C Posted October 23, 2006 Report Share Posted October 23, 2006 Ali C will tell you to get a V. - Avid Ultimate..Becuase he prefers them compared to a Magura. DAM RIGHT I WILL! Quote Link to comment Share on other sites More sharing options...
Brian Bleech Posted October 23, 2006 Report Share Posted October 23, 2006 DAM RIGHT I WILL! AND I WILL BACK HIM UP.... *awaits pauloliver...* Quote Link to comment Share on other sites More sharing options...
Tommy d Posted October 23, 2006 Report Share Posted October 23, 2006 DAM RIGHT I WILL! I was waiting for that...Don't think anybody has mentioned yet that you don't need a front disc if you don't want one. Magura HS33 (i.e. hydraulic rim brake) or good quality V-brake will also do the trick.It's probably easiest just to get whatever type your frame/forks are compatible with unless you have a preference. Quote Link to comment Share on other sites More sharing options...
Jaffacakes Posted October 23, 2006 Report Share Posted October 23, 2006 Dual maggy all the way. Disk's suck Except filthy cable disk's I suppose, The rotor's still like snapping though... Quote Link to comment Share on other sites More sharing options...
Phil H Posted October 23, 2006 Report Share Posted October 23, 2006 Dual maggy all the way. Disk's suck Except filthy cable disk's I suppose, The rotor's still like snapping though...Wouldnt go as far as to say disks suck but I run maguras front and rear and seem to do the job! As I see it a disk is just more likely to get destroyed but what do I know - If good riders use Disk up front and magura on the back I think that says enough.Phil Quote Link to comment Share on other sites More sharing options...
Chris Elson Posted October 23, 2006 Report Share Posted October 23, 2006 Front disk , rear maggie, i wouldnt go with dual disk. But wouldnt mind going with front and back maggies. Cant beat a hs33 Quote Link to comment Share on other sites More sharing options...
quasi_mojo Posted October 24, 2006 Report Share Posted October 24, 2006 I've been using an LX front V with a BMX lever, works lovely, but i would say that because i have to make do at the moment, rear maggie is essential, although one of my riding buddies uses a rear disk (the frame cant accomodate his huge try-all rim!), with abit of cola on it works lovely too...i think my front V is lighter than a maggie with a booster, but i don't really use the front brake that much! try using bikes with different brake configurations and see which you like best...at the end of the day its your bike... Quote Link to comment Share on other sites More sharing options...
kid creole Posted October 24, 2006 Report Share Posted October 24, 2006 (edited) Dual maggy all the way. Disk's suck Except filthy cable disk's I suppose, The rotor's still like snapping though...dual maguras are ok but it means you have to buy 2 sets of expensive pads when your grind eats them . but with disks the pads take forever to wear away ive never replaced them and the brakes perfect saves money i think.also with front disk you can whip the wheel off in a second to put the bike in your car if your going somewhere Edited October 24, 2006 by Alain Quote Link to comment Share on other sites More sharing options...
afro dude Posted October 24, 2006 Report Share Posted October 24, 2006 On my DDG i have very good v-brakes but there a bit sluggish but on my other bike i have magura's and they are so much better.But some people have front disc brakes and back disc brakespersonal i think having a back disc brake dosen't fell as good as a backmagura. But a front disc is ok. But the choose is yours. Quote Link to comment Share on other sites More sharing options...
GTF Posted October 24, 2006 Report Share Posted October 24, 2006 Dual magura or vee Quote Link to comment Share on other sites More sharing options...
1337 Trials Posted October 24, 2006 Report Share Posted October 24, 2006 Personal preferance.I run a 160mm Avid BB7 up front on my Zona. - Mechanical disc brake.And a Magura HS33, Plaz pads on the back. - Hydraulic rim brake.Ali C will tell you to get a V. - Avid Ultimate..Becuase he prefers them compared to a Magura. yoyo! Im thinking of gettin a avid bb7 for xmas built onto a echo rim with , hmmmm, not sure what hub yet . Anyway most people say with the bb7 get new cable and lever or is the lever and cable that comes with the disc good? P.s. What is your overall view on the avid bb7 disc brake??? ~Matty Quote Link to comment Share on other sites More sharing options...
Ali C Posted October 24, 2006 Report Share Posted October 24, 2006 the avid bb7 is very good! best disk out for trials I think.They dont come with cable or lever though, so you have to buy those seperatly.PS get a vee!!! Quote Link to comment Share on other sites More sharing options...
MadManMike Posted October 24, 2006 Report Share Posted October 24, 2006 I use Avid cable Vees and they are sharp as hell, one finger used too.and for the record, no grinds or tar being used, so I don't know why you guys have so much trouble Quote Link to comment Share on other sites More sharing options...
1337 Trials Posted October 24, 2006 Report Share Posted October 24, 2006 ok, is that why there so cheap? hehe. Anyway, what cable/lever works well??? ~Matty Quote Link to comment Share on other sites More sharing options...
Trials Maniac Posted October 24, 2006 Report Share Posted October 24, 2006 Magura HS33 (hydraulic rim) on the rearHope mono trial (Hydralic disc) on the frontThe BEST setup Adam Quote Link to comment Share on other sites More sharing options...
Ali C Posted October 24, 2006 Report Share Posted October 24, 2006 my worst nightmare! Quote Link to comment Share on other sites More sharing options...
Trials Maniac Posted October 24, 2006 Report Share Posted October 24, 2006 lol!! but you dont like magura!! Quote Link to comment Share on other sites More sharing options...
kid creole Posted October 24, 2006 Report Share Posted October 24, 2006 (edited) my worst nightmare!whys that your worst nightmare ???? there not that bad surely!!! Edited October 24, 2006 by Alain Quote Link to comment Share on other sites More sharing options...
Trials Maniac Posted October 24, 2006 Report Share Posted October 24, 2006 whys that your worst nightmare ???? there not that bad surely!!!he doesn't like maguras, much, well at all really!! Quote Link to comment Share on other sites More sharing options...
COCK Posted October 24, 2006 Report Share Posted October 24, 2006 use a cock as a brake Quote Link to comment Share on other sites More sharing options...
Ali C Posted October 24, 2006 Report Share Posted October 24, 2006 heh heh, I think they are fine, but vees are just nicer.....the hope on the other hand, give me anything but a hope! Quote Link to comment Share on other sites More sharing options...
