20inchsuperstar Posted October 21, 2006 Report Share Posted October 21, 2006 does what it says on the tin, well title you know. any stock riders do it or is it a mod thing? Quote Link to comment Share on other sites More sharing options...
Guest Posted October 21, 2006 Report Share Posted October 21, 2006 A good few comp rider's do. Ben savage definately does. Quote Link to comment Share on other sites More sharing options...
20inchsuperstar Posted October 21, 2006 Author Report Share Posted October 21, 2006 A good few comp rider's do. Ben savage definately does.cheers it's swinging towards the front freewheel, just look at the line.. freehub / freewheel Quote Link to comment Share on other sites More sharing options...
Savage Posted October 21, 2006 Report Share Posted October 21, 2006 A good few comp rider's do. Ben savage definately does.NEVER used anything else. Ben. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted October 21, 2006 Report Share Posted October 21, 2006 A couple of the scousers do it, A couple of riders here do it tooGo for it Quote Link to comment Share on other sites More sharing options...
Synergy Posted October 21, 2006 Report Share Posted October 21, 2006 mates got a tensile 72 click freewheel on his adamant a1 at the moment, to be honest i cant relaly find a difference apart from maybe in egadments between a front freewheel bike and a read driven hub one. just price. Quote Link to comment Share on other sites More sharing options...
chrishayton Posted October 21, 2006 Report Share Posted October 21, 2006 all the koxx riders do it, eg hermance, TRA, my mate has fw, seems fine, works just as good as it would on a mod Quote Link to comment Share on other sites More sharing options...
20inchsuperstar Posted October 21, 2006 Author Report Share Posted October 21, 2006 cheers guys, the freewheel-o-meter says freehub _ front freewheel Quote Link to comment Share on other sites More sharing options...
grantham Posted October 21, 2006 Report Share Posted October 21, 2006 yer i run front freewheel on a stock as well, ive had two kings and i prefer the freewheel any day. Quote Link to comment Share on other sites More sharing options...
20inchsuperstar Posted October 21, 2006 Author Report Share Posted October 21, 2006 (edited) freewheel-o-meter says front freewheel nitey nite Edited October 21, 2006 by 20inchsuperstar Quote Link to comment Share on other sites More sharing options...
GTF Posted October 22, 2006 Report Share Posted October 22, 2006 I believe that someone uses front freewheel, altrought that i dont like them Quote Link to comment Share on other sites More sharing options...
Orgun_Donor Posted October 23, 2006 Report Share Posted October 23, 2006 im currently running a front freewheel. tis very very nice! Quote Link to comment Share on other sites More sharing options...
Jaffacakes Posted October 23, 2006 Report Share Posted October 23, 2006 im currently running a front freewheel. tis very very nice!What happened to the profile? Quote Link to comment Share on other sites More sharing options...
eskimo Posted October 23, 2006 Report Share Posted October 23, 2006 Front freewheel is suppost to be cheaper and lighter. Only slightly on both cases though. Depending setup i guess.I did find one problem. Chain tension when the bb axle is bent. It makes it so annoying. When manualing on a bumpy surface the chain sometimes comes off i found. Quote Link to comment Share on other sites More sharing options...
theone2be Posted October 23, 2006 Report Share Posted October 23, 2006 Oh god after reading this topic i'm thinking of selling the king and buying a fixed hub and an eno. I wonder shall i do it? Quote Link to comment Share on other sites More sharing options...
Guest Posted October 23, 2006 Report Share Posted October 23, 2006 Front freewheel is suppost to be cheaper and lighter. Only slightly on both cases though. Depending setup i guess.I did find one problem. Chain tension when the bb axle is bent. It makes it so annoying. When manualing on a bumpy surface the chain sometimes comes off i found.The way I see it, for those riding recreationally, it's 6 of one, half a dozen of the other..... When it comes to competeing and such in theorey it's probobly a better idea to run front freewheel, unless your so particular that you can tell the differance between front and back with your feet.If your front freewheel goes tit's up, it's easy to swap freewheel's/cranks around quickly, it's not soo easy to swap out a rear wheel, and even harder again to replace just the hub(wheel build etc) not to mention the fact that's it's easier to carry around a spare freewheel/crank arm in a bag than a full back wheel. Regarding riding with a bent BB, that's not something many people do is it? so i don't see it as an issue really, and in the time i've started riding again, riding mod since march, my chain has never come off once no matter what I do, with a good tensioner i can also see that not being an issue. Quote Link to comment Share on other sites More sharing options...
20inchsuperstar Posted October 24, 2006 Author Report Share Posted October 24, 2006 thanks very much guys front freewheel it is! i cant decide which one though... tensile or spend a bit more (alot more) and get an eno?Matt Quote Link to comment Share on other sites More sharing options...
Orgun_Donor Posted October 24, 2006 Report Share Posted October 24, 2006 What happened to the profile?f**ked up a second time, 2 days to repair it, and they replaced every thin but the 8mm bolts, lock ring and cog. but then i sold it to Alex for cheap. Now running front ENO, and rear T-Master which is working a treat a loads cheaper then my other set up! Quote Link to comment Share on other sites More sharing options...
GTF Posted October 25, 2006 Report Share Posted October 25, 2006 Oh god after reading this topic i'm thinking of selling the king and buying a fixed hub and an eno. I wonder shall i do it?Don´tIn that chase, sell me your hub Quote Link to comment Share on other sites More sharing options...
TRA Posted October 25, 2006 Report Share Posted October 25, 2006 get a try-all freehweel, most clicks, VERY strong ,its black , and its cheap Quote Link to comment Share on other sites More sharing options...
nafan Posted October 25, 2006 Report Share Posted October 25, 2006 Someone told me not to cos' its sh*t, but frankly that's shash...I'm gonna be running it soon, as long as you have a decent freewheel maintenence is a minimum compared to freehubbing...Nathan Quote Link to comment Share on other sites More sharing options...
