trials wannabe Posted October 20, 2006 Report Share Posted October 20, 2006 ask you can probably tell im new but i just wanted to know why its squeaking it was cold to day and my mate said its probably freazing up and if its normal to do that can you say please and if not how to fix it so it doesnt?thanks Quote Link to comment Share on other sites More sharing options...
lawrence osborn Posted October 20, 2006 Report Share Posted October 20, 2006 How can oil freeze no myne does it aswell it just what it does sometimes Quote Link to comment Share on other sites More sharing options...
Egg Fried Rice Posted October 20, 2006 Report Share Posted October 20, 2006 its probably because you have a slighty warped disc or u caliper isnt set straightJK Quote Link to comment Share on other sites More sharing options...
bennyb Posted October 20, 2006 Report Share Posted October 20, 2006 yer i warped my disc so i bent it back now its fine mate ..... Quote Link to comment Share on other sites More sharing options...
trials wannabe Posted October 20, 2006 Author Report Share Posted October 20, 2006 lol thx guys Quote Link to comment Share on other sites More sharing options...
Tomm Posted October 20, 2006 Report Share Posted October 20, 2006 If it's squeaking a lot, it could be that you've got some oil on the disc, but it sounds like it's probably just the weather. If it's still as powerful as it should be, just leave it alone. Quote Link to comment Share on other sites More sharing options...
nmt_oli Posted October 20, 2006 Report Share Posted October 20, 2006 If its not too expensive at your local bike shop, get your mounts faced. it makes them exactly parralel with each other and the drop out, meaning the caliper should sit dead straight over the disk, not slightly off, which can cause a noisy brake.I actually bought the hope facing tool, as i have 4 frames (and a fair few forks) with disk mounts, so was more cost effective to buy the tool (even at £70). ive found it to be very benificial. Quote Link to comment Share on other sites More sharing options...
Greetings Posted October 20, 2006 Report Share Posted October 20, 2006 Might as well ask in this topic seeing as it's a bit related. Bought a used Hope lever recently and it's creaking when I press it hard. I had the same problem with my old lever, it doesn't influence the performance, just drives me crazy Is there a way of getting rid of that noise? Quote Link to comment Share on other sites More sharing options...
Broomer Posted October 20, 2006 Report Share Posted October 20, 2006 Might as well ask in this topic seeing as it's a bit related. Bought a used Hope lever recently and it's creaking when I press it hard. I had the same problem with my old lever, it doesn't influence the performance, just drives me crazy Is there a way of getting rid of that noise?yeah my hope lever did that dap some oil on the lil linkage thing on the leverblade, that solved it Quote Link to comment Share on other sites More sharing options...
Hendy Posted October 20, 2006 Report Share Posted October 20, 2006 u may of worn the pads away just take the wheek off and have a look Quote Link to comment Share on other sites More sharing options...
bennyb Posted October 20, 2006 Report Share Posted October 20, 2006 yer i remeber when i took mine apart and took half hour to put it back togeather ....hahahahahahaa f**king idiot ...lol.. :$ Quote Link to comment Share on other sites More sharing options...
trials wannabe Posted October 20, 2006 Author Report Share Posted October 20, 2006 lol thats the point im new to disc brakes im most likely to mess up Quote Link to comment Share on other sites More sharing options...
