Matthew_Gibson Posted October 19, 2006 Report Share Posted October 19, 2006 There's a noise coming from the front end. I don't know where its coming from. I noticed this when I was back hopping and my forks/front wheel seemed, like, bouncing. I could feel them moving too. Can anyone help me out. I'm going to go and take the forks off now and have a look at the headset etc. but if any on you guys can help me that would be great. Thanks for your time! Quote Link to comment Share on other sites More sharing options...
Greetings Posted October 19, 2006 Report Share Posted October 19, 2006 Undo the bolts on your stem, tighten the screw on the headset cap and then screw down the stem. Should help. If not, you've got bearing problems or something similar. Quote Link to comment Share on other sites More sharing options...
nafan Posted October 19, 2006 Report Share Posted October 19, 2006 I think I have the same problem, a sort out creaking cracking sound?If it is it will be fine, I've got used to it, I think its either steerer length or headset bearings, I think it's steerer length as mine has only done it since I got my new forks...Try adding some headset spacers, failing that you may need a new headset...Nathan Quote Link to comment Share on other sites More sharing options...
Fixed Pants™ Posted October 19, 2006 Report Share Posted October 19, 2006 My forks wobble in the headset, which is annoying, but creaking normally means its about to crack? Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted October 19, 2006 Author Report Share Posted October 19, 2006 (edited) If not, you've got bearing problems or something similar. The bearing on the bottom of my head set are f**ked, I think. They don't seem to go into the frame, I can move the forks about 5mm forward and backwards. Unsafe to ride. But i have no idea what to do, New headset? new bearings? Edited October 19, 2006 by Matt Gibson Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted October 19, 2006 Author Report Share Posted October 19, 2006 [attachmentid=7658] Quote Link to comment Share on other sites More sharing options...
Greetings Posted October 19, 2006 Report Share Posted October 19, 2006 (edited) The bearing highlited in green is upside down. Edited October 19, 2006 by Inur Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted October 19, 2006 Author Report Share Posted October 19, 2006 The bearing highlited in green is upside down.I had it like that and the other way still no different. But i cant do anything as its too dark! Quote Link to comment Share on other sites More sharing options...
RobinJI Posted October 19, 2006 Report Share Posted October 19, 2006 (edited) Hey, from the diagram I'm guessing you've got a pig. If so then You have probably just shagged the lower bearings, just find some at you're local bike shop. Or if you want a quick fix then pop the remaining balls out of the cage, and just put them in loose, just stick them to the cup with some thick greese while you put it back together, if you dont think that leaves enough bearings then just nab some 1/4 inch bearings out of anything else, like an old loose ball hub so that the bottom cup if full of bearings. Although fiddily, its actualy stonger than having the cage in! Edited October 19, 2006 by Dont you Just Hate it When... Quote Link to comment Share on other sites More sharing options...
N.Wood Posted October 19, 2006 Report Share Posted October 19, 2006 Hey, from the diagram I'm guessing you've got a pig. If so then You have probably just shagged the lower bearings, just find some at you're local bike shop. Pig lower balls are over sized and no bikeshops sell them though? They're huge!Check your forks arn't about to die, i thought my headset was loose, but then my forks came apart at the steerer/crown interface. Quote Link to comment Share on other sites More sharing options...
Guest Posted October 19, 2006 Report Share Posted October 19, 2006 I ran a pig with 4 or 5 bearing's loose, without a crown race for ages when I was 13 or 14 or so, lasted for ages and ran sweet. Quote Link to comment Share on other sites More sharing options...
RobinJI Posted October 19, 2006 Report Share Posted October 19, 2006 Pig lower balls are over sized and no bikeshops sell them though? They're huge!Check your forks arn't about to die, i thought my headset was loose, but then my forks came apart at the steerer/crown interface. Yeah, its hard to get get hold of them cagged, but there 1/4inch which is the standard size for hubs like Deores, so just get some of those and run em loose Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted October 19, 2006 Author Report Share Posted October 19, 2006 Chain reaction cycles sell them so I'll see, But I work at halfords so I can get some from there. But its deffo not the forks i had sure of that! Quote Link to comment Share on other sites More sharing options...
