t33zr Posted October 19, 2006 Report Share Posted October 19, 2006 Concidering to buy a 06 Monty ti with dualdisc... But i wonder how its like to sidehop with dualdisc when i sidehop to left...Will my rear disc crush if i miss the sidehop? Quote Link to comment Share on other sites More sharing options...
poopipe Posted October 19, 2006 Report Share Posted October 19, 2006 Concidering to buy a 06 Monty ti with dualdisc... But i wonder how its like to sidehop with dualdisc when i sidehop to left...Will my rear disc crush if i miss the sidehop?if you land on the disk it'll probably bend a bit. I bent my front one a bit (not enough to stop the wheel turning) once and it just kinda straightened itself out as I used it. Quote Link to comment Share on other sites More sharing options...
Shaun H Posted October 19, 2006 Report Share Posted October 19, 2006 Concidering to buy a 06 Monty ti with dualdisc... But i wonder how its like to sidehop with dualdisc when i sidehop to left...Will my rear disc crush if i miss the sidehop?Front one, I imagine, should be ok as noone ever really slips and if they do their bars are usually turned. However the rear one could be a bit buggered, that's alot of weight for a thin (relatively speaking) steel disc to take. If you always fell onto it perfectly vertical it'd be ok, but that's not gunna happen so it will probably bend if you miss a sidehop badly. Quote Link to comment Share on other sites More sharing options...
GTF Posted October 19, 2006 Report Share Posted October 19, 2006 Havent you just bought a new Ko-bike? I belive that the rear disc will break pretty fast. I dont know as i never have tried double disc Quote Link to comment Share on other sites More sharing options...
Davetrials Posted October 19, 2006 Report Share Posted October 19, 2006 it wont break if u sidehop properly with ur bike at an angle to the wall. Quote Link to comment Share on other sites More sharing options...
RobinJI Posted October 19, 2006 Report Share Posted October 19, 2006 Yeah, again, if you sidehop properly then the bike will be at an angle, so the tyre will hit before the disc. Should be alright, I've cocked around doing trials moves on dual disc Jump bikes loads and never bent a disc, despite coming short loads. Quote Link to comment Share on other sites More sharing options...
loffa Posted October 19, 2006 Report Share Posted October 19, 2006 It is really hard to hit the rear disk on a missed sidehop, as it is protected by your rear tire (if you look straight up from the "ground" you can't see the rotor because the tire is wide enough to protect it. Kinda hard do explain but hopefully you got it). As said before your tire or pedal will hit first. Actually the only way I can think of hitting the rear rotor is by missing BOTH wheels on a sidehop. Quote Link to comment Share on other sites More sharing options...
matt! Posted October 22, 2006 Report Share Posted October 22, 2006 Concidering to buy a 06 Monty ti with dualdisc... But i wonder how its like to sidehop with dualdisc when i sidehop to left...Will my rear disc crush if i miss the sidehop?yes, but if you are lucky you may miss it, but it extrmely tight to miss it! Quote Link to comment Share on other sites More sharing options...
Greetings Posted October 22, 2006 Report Share Posted October 22, 2006 (edited) Rode a 221Ti with a 180mm rotor on the rear, sidehopped to the left and never hit it.Rode a GU Short with a 203mm rotor on the rear, missed quite a few sidehops, never hit the rotor. Edited October 22, 2006 by Inur Quote Link to comment Share on other sites More sharing options...
Chris_Walker Posted October 22, 2006 Report Share Posted October 22, 2006 Hi,i have run double disc montys for a long time now and i have never had any problems with them when a sidehop goes wrong and my sidehops usually go wrong.You will be fine with double disc u will never want to go backMONTY are the best anywaysChris Quote Link to comment Share on other sites More sharing options...
Gaz M Posted October 22, 2006 Report Share Posted October 22, 2006 I had a 221 ti with a 160 rotor on the back, smashed the hell out of it on missed sidehops Quote Link to comment Share on other sites More sharing options...
GTF Posted October 22, 2006 Report Share Posted October 22, 2006 You can just put on a magura Quote Link to comment Share on other sites More sharing options...
_skj0lsvik_ Posted October 22, 2006 Report Share Posted October 22, 2006 You can just put on a magura The dual disc is the half point about buying the monty. Would YOU waste half the point of buying a bike? Quote Link to comment Share on other sites More sharing options...
matt! Posted October 22, 2006 Report Share Posted October 22, 2006 (edited) You can just put on a magura 07 monty with magura mounts, thats a first. Edited October 22, 2006 by matt! Quote Link to comment Share on other sites More sharing options...
t33zr Posted October 22, 2006 Author Report Share Posted October 22, 2006 (edited) I just realised that i ride PRETTY hard....My chainstay is all over smashed by missed sidehops, and i had my ko-bike for like 2-3 months...I wont buy a monty if i will smash the disc in a week... anyway... people here have different opinions... some say the disc wont touch, and some say it will crack...Maybe i wil buy a Pr instead? then i can put on maggies if i change my mind....? Edited October 22, 2006 by t33zr Quote Link to comment Share on other sites More sharing options...
omgnoseat Posted October 22, 2006 Report Share Posted October 22, 2006 I just realised that i ride PRETTY hard....My chainstay is all over smashed by missed sidehops, and i had my ko-bike for like 2-3 months...I wont buy a monty if i will smash the disc in a week... anyway... people here have different opinions... some say the disc wont touch, and some say it will crack...Maybe i wil buy a Pr instead? then i can put on maggies if i change my mind....?the pr has magura marta disc brakes, but the montey has hope mono trial which is alot better.the marta might not be as strong as magies so i'm not sure if you will like the pr..i'm getting my pr next week (hopefully tomorrow or tuesday), you could wait 2 or 3 days so i can tell how the marta feels compared to magies Quote Link to comment Share on other sites More sharing options...
Joe_Elding Posted October 22, 2006 Report Share Posted October 22, 2006 IMO magura martas are better than hope mono trials. Quote Link to comment Share on other sites More sharing options...
omgnoseat Posted October 22, 2006 Report Share Posted October 22, 2006 IMO magura martas are better than hope mono trials.i really hope this is true but its hard to believe I'm pretty sure that the hope mono trial is better since it is made for trials and the marta isn'tmaybe the one you had a ride one didnt bed in yet Quote Link to comment Share on other sites More sharing options...
Joe_Elding Posted October 22, 2006 Report Share Posted October 22, 2006 there wasn't really a difference in power on the two I was on, they were both f**king powerful, I just felt that the marta had a nicer feel, and felt a lot more solid than the hope, and also the martas (I have found) to be a lot less temperamental than the hope.but still, neither of them are gonna be bad disc brakes. Quote Link to comment Share on other sites More sharing options...
spode@thinkbikes Posted October 23, 2006 Report Share Posted October 23, 2006 You can just put on a magura ROFL!!!!Oh, wait - you were being serious?I personally side hop to the right, so hitting discs isn't a problem. But team-mate Dave side hops to the left and I don't think he's ever had to replace a rotor.Those dual-disc Montys are absolutely superb bikes - if you have the money, get one. Quote Link to comment Share on other sites More sharing options...
oakley Posted October 23, 2006 Report Share Posted October 23, 2006 I just realised that i ride PRETTY hard....My chainstay is all over smashed by missed sidehops, and i had my ko-bike for like 2-3 months...I wont buy a monty if i will smash the disc in a week... anyway... people here have different opinions... some say the disc wont touch, and some say it will crack...Maybe i wil buy a Pr instead? then i can put on maggies if i change my mind....?yes but have you noticed all the people but one who say you WILL hit the disc have never even used one! where as me and chrios walker have used them for over a year, and we both sidehop to the left, and i have never, not even once, hit mine when sidehopping!IMO magura martas are better than hope mono trials.next joke! Quote Link to comment Share on other sites More sharing options...
t33zr Posted October 23, 2006 Author Report Share Posted October 23, 2006 Thanx for the info... maybe i just have to try then....I dont think i can afford a bike before christmas, but maybe after.... Quote Link to comment Share on other sites More sharing options...
Sam Oliver Posted October 25, 2006 Report Share Posted October 25, 2006 (edited) IMO magura martas are better than hope mono trials.Can you explain why please? On my second ddisk Monty, & never hit the disk I sidehop both ways Edited October 25, 2006 by SamMonty Quote Link to comment Share on other sites More sharing options...
spode@thinkbikes Posted October 25, 2006 Report Share Posted October 25, 2006 Can you explain why please? On my second ddisk Monty, & never hit the disk I sidehop both ways Can you side hop the same height both ways? I can side hop to the opposite direction but no-where near as high. Quote Link to comment Share on other sites More sharing options...
Egg Fried Rice Posted October 25, 2006 Report Share Posted October 25, 2006 magura martas are the shizzle...i have the marta SL and its doing me goodJK Quote Link to comment Share on other sites More sharing options...
