Area...how you Work It Out
Wright Pads
Okay sorting these pads out now...got a day of work so gonna get lots done.
Deceied that 8mm is enough, less is not an option, more creats issuews with you using it! Thanks to FatMike on his part there!
Right 300x300mm sheet, i need to cut out 50x12mm blocks! How is it you work out the aera thing...so i know how manny i'll get!
I need to know as i need to conferm number of backings, and then get enough glue as this wil be a mass session of cutting and glueing and packing!
Anyone fancy showing me up on my math skills!!! I have really lost the plot on how to do it!
Free set of pads in it for the 1st correct answer!
C'mon
that's 6 pads across in length at 50mm a pad (300/50), by 25 pads at 12mm a pad's width (300/12),
so you can cut out 6x25 = 150 pads, that's 75 pairs.
The real question is, can you cut clean or do you loose material when you cut?
Because even 1/2mm of line cut means you'd have less pads
Hope this helps ;)
obviously you will make 72 sets of pads if you are skilled cutter)))
considering that there will be a quantity of the defective ones you could produce up to 65 pairs of a good kosher sets :)
plus you need to make some "prototypes" that would be tested by 3-5 riders to reveal how good they are in the different conditions (smooth/groun rim, wet/dry weather etc)
i mean, that you are responsible for you pruduction and you must be assured in quality :P
cheers
Edited by jacks
Darren is the winner! Free set of pads for him!
Pads have been tested, devloped, and used by manny already but under a differnt name, i now do them as the old guy no longer has time!
The way they will be cut into the blocks is very skilled, 0.5mm +/- infact.
Just need to order the backings now!
Glad i didn't order 27 backings and as for the LTD run number well 75 sets will keep many happy!
Riht time to get on the dog n bone and get these cut into blocks for cutting to fit the backings
