Hope Mono Trial
lawrence osborn
If its coming from the lever try wacking some WD40 or greese on the little brass barrel that the reach adjuster screws into, and on the pivot.
If its coming from the caliper check that the pads are warn evenly, my LX did it because one of the pads was warn unevenly and the piston creaked as it twisted in the caliper when you pulled it hard.
