cornishpasty Posted October 18, 2006 Report Share Posted October 18, 2006 hiy all, first i would like to know, what year did the blue magura hs33s come out. thanks.and 2 is what size bolt do i get the one which holds the two halves of the evolution adaptors together.im looking at the ones on chainreactioncycles.com. there are three different types! Evo II M5x34mm x 2 New M5x32mm x 2 Old M5 x25mm x 2and how do i know what size to get?? !!thanks alot. josh Quote Link to comment Share on other sites More sharing options...
T-OM Posted October 18, 2006 Report Share Posted October 18, 2006 i think they where 03 or 04 but i wouldnt get em if i was you i got one and it cracked Quote Link to comment Share on other sites More sharing options...
cornishpasty Posted October 18, 2006 Author Report Share Posted October 18, 2006 i think they where 03 or 04 but i wouldnt get em if i was you i got one and it cracked what cracked?? bolt?? or brake??? i got the blue ones!! Quote Link to comment Share on other sites More sharing options...
Grizzly Posted October 18, 2006 Report Share Posted October 18, 2006 Oh you have the brakes then. That helpsIf you look on the underside of one of the cylinders it should have a number eg. '04' in a circle. Its rather small but easily defined. Thats the year of it Hope that helps.Also i take it he meant the lever snapped, as the same thing happened to me Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted October 18, 2006 Report Share Posted October 18, 2006 Mk1's are the ones you have, erm 99 onwards i think upto 2004 ish!^ Should be the ones you got but blue and ether sliver or black leaver.They be the best ones!The bolt you need for the original evo mount where the booster sits is a M5 and 32mm, thats for the one thats ha black plastic elbows! Any M5 bolt will do!Hope that helps Quote Link to comment Share on other sites More sharing options...
cornishpasty Posted October 18, 2006 Author Report Share Posted October 18, 2006 Mk1's are the ones you have, erm 99 onwards i think upto 2004 ish!^ Should be the ones you got but blue and ether sliver or black leaver.They be the best ones!The bolt you need for the original evo mount where the booster sits is a M5 and 32mm, thats for the one thats ha black plastic elbows! Any M5 bolt will do!Hope that helpscheers mate. rely helped!thanks again,joshjust to make dure should i go for 32mm or 34mm??cheers josh Quote Link to comment Share on other sites More sharing options...
