domonza Posted October 18, 2006 Report Share Posted October 18, 2006 As the title says how do you get an egg buckle out a wheel? Let me no, would be a great help Thanks in advance DOM Quote Link to comment Share on other sites More sharing options...
munkee Posted October 18, 2006 Report Share Posted October 18, 2006 Where theres a high spot you tighten the 3 spokes coming from the 3 spoke holes directly below that point. So you would tighten for instance a spoke oneside, then the other side, then back the other side you started on. You can tighten more than 3 spokes (its just easier to not get so confused where you have done) but just make sure you tighten both sides of the wheel the same amount and only in the area where the egging is. When you do this you pull the high spot down since you're tightening, but dont lose left and right truing due to tightening both sides of the wheel equal amounts. Quote Link to comment Share on other sites More sharing options...
domonza Posted October 18, 2006 Author Report Share Posted October 18, 2006 alright thanks m8 will give that a go DOM Quote Link to comment Share on other sites More sharing options...
