Couple Of Questions
luke_onza
Hi lads.
I have a couple of things I would like to ask you.
First dose anyone on here live in Cumbria? I am sick of riding by myself all the time as there is no one how doses trials that I know.
Second thing, dose anyone bleed there magura rim break on water? I was recommended to do it by Jordy Cook. I think that it is loads better. Water is a solid compound so it cannot compress so when you pull your break on it is so solid. If any of you do try it make shore you put some antifreeze in as well, it only works with the old hs33 because with the new ones it just strips the threads on the adjuster.
luke
