Tim-Hill..Yeah Mate Posted October 17, 2006 Report Share Posted October 17, 2006 Hi,i've got a new rim coming so i have to un-spoke my rim, i tried before but i bent about 10 spokes, i just unscrewed and pulled out and i don't want to spend another 10£ buying new spokes this time!is there any pattern i have to do?thanksTim. Quote Link to comment Share on other sites More sharing options...
26inch Posted October 17, 2006 Report Share Posted October 17, 2006 no, special patten just be careful, you should always use new spokes anyway as the wheel will last better Quote Link to comment Share on other sites More sharing options...
eskimo Posted October 17, 2006 Report Share Posted October 17, 2006 no, special patten just be careful, you should always use new spokes anyway as the wheel will last betterLast longer you mean? He is right though, then it will bed it nicely.Or you could just loosen all the spokes off slightly and evenly all the way round. Then just switch them one by one onto your new rim. Tighten evenly all the way round again when there on your new rim. Quote Link to comment Share on other sites More sharing options...
Tim-Hill..Yeah Mate Posted October 17, 2006 Author Report Share Posted October 17, 2006 Quote Link to comment Share on other sites More sharing options...
eskimo Posted October 17, 2006 Report Share Posted October 17, 2006 So your de-spoking your wheel to take the rim off so you can send the hub and spoke to somewhere to be built? Am i reading your post correctly? Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted October 17, 2006 Report Share Posted October 17, 2006 Are they the right length for your new rim/hub/whatever?Need to be close enough else tensions will be out and it will be a bit screwed... Quote Link to comment Share on other sites More sharing options...
bhups Posted October 17, 2006 Report Share Posted October 17, 2006 (edited) Tape the 2 rims (the old wheel rim with the spokes and hub and the new rim) up together with the valve hole at the same place then 1 by 1 go around switching them over to your new rim. Tighten them evenly about 4 or 5 turns per spoke when switiching them then go around giving a half turn each spoke till the spokes are tight and true. Edited October 17, 2006 by bhups Quote Link to comment Share on other sites More sharing options...
Tim-Hill..Yeah Mate Posted October 17, 2006 Author Report Share Posted October 17, 2006 yeh, i'm keeping same hub and spokes and same size rim so i'm not going to need different length spokeshad the 06 echo, getting 07 as i gave the 06 a few flat spots and it got dodgy.Tim. Quote Link to comment Share on other sites More sharing options...
eskimo Posted October 17, 2006 Report Share Posted October 17, 2006 (edited) Tape the 2 rims (the old wheel rim with the spokes and hub and the new rim) up together with the valve hole at the same place then 1 by 1 go around switching them over to your new rim and tighten then true them out.Same as what i said. But i'm going from what he said so i don't think he wants to true it out as he is not confident in doing that, i guess?[edit] grammer problems Edited October 17, 2006 by eskimo Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted October 17, 2006 Report Share Posted October 17, 2006 yeh, i'm keeping same hub and spokes and same size rim so i'm not going to need different length spokeshad the 06 echo, getting 07 as i gave the 06 a few flat spots and it got dodgy.Tim.Cool, should be ok then, although I haven't checked the ERD on the '06/'07s so you may want to to be certain, but I think you'll be ok Quote Link to comment Share on other sites More sharing options...
Tim-Hill..Yeah Mate Posted October 17, 2006 Author Report Share Posted October 17, 2006 Yepthanks guys!i'm un-spoking tomorrow, so i just have to do it carefully then and don't rush or yank them out, hopefully goes well! Tim. Quote Link to comment Share on other sites More sharing options...
RobinJI Posted October 17, 2006 Report Share Posted October 17, 2006 Hey, to avoid bending them just undo them all, then uncross them and take them out without the rim on there. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted October 17, 2006 Report Share Posted October 17, 2006 You probably wont be able to use the same spokes again, unless you're getting the same rim.Different lengths and all that. Quote Link to comment Share on other sites More sharing options...
ben Posted October 18, 2006 Report Share Posted October 18, 2006 if u compleatly undo each spoke then u can move the hub round and slide the spokes out easy peasie. ben Quote Link to comment Share on other sites More sharing options...
bike rider Posted October 18, 2006 Report Share Posted October 18, 2006 get a professinol to do it eg halfords Quote Link to comment Share on other sites More sharing options...
eskimo Posted October 18, 2006 Report Share Posted October 18, 2006 get a professinol to do it eg halfordsSince when have Halfords been profesionals with bikes? Quote Link to comment Share on other sites More sharing options...
Alun Goch Posted October 18, 2006 Report Share Posted October 18, 2006 Remove all the nipples, hold the rim on its side, twist the hub one way till half the spokes come out, then the same twisting the other way, and bobs yer mothers brother!Alun Quote Link to comment Share on other sites More sharing options...
Tim-Hill..Yeah Mate Posted October 18, 2006 Author Report Share Posted October 18, 2006 (edited) Hi,i almost got it.. i bent about 3 or 4 spokes not too bad for a first attempt. i think now i'll just get new spokes as the ones i have now are obviusly going to be weaker but now i need to know what size to get, i think its 185mm but not sure, i have a echo screw in hub http://www.tartybikes.co.uk/product.php?id=227 and echo 07 rim, can anyone tell me the exact size i need?thanksTim. Edited October 18, 2006 by Tim H Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted October 18, 2006 Report Share Posted October 18, 2006 Why...When you build a new rim you bend the spokes no matter what you do! I have tried it to build a wheel inhand and side the rim in but it's not easy!The amount of tension you have to aply pulls the spokes tight and streight and it's really minamula bending you need to do!Anyway undo all nipples, twist the hub a little in drive direction, and pull the hub n da spoke out, then fondel the hub at ether end to et them out!Dead easy Quote Link to comment Share on other sites More sharing options...
Tim-Hill..Yeah Mate Posted October 18, 2006 Author Report Share Posted October 18, 2006 ive taken all spokes and as i already said, but i kind of buggerd 2 up.. tried to bodge true my wheel with a pair of pliers and i made the nipple ovel shape so spoke doesnt screw in, do you think my lbs will have right size and strength?Tim. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted October 18, 2006 Report Share Posted October 18, 2006 who cares about new spokes, im using the first set of new spokes ive owned in 2 years at the moment, continuesly breaking and changing rims.have fun, good luck with the new wheel. Quote Link to comment Share on other sites More sharing options...
