T.McMillan Posted October 15, 2006 Report Share Posted October 15, 2006 (edited) The hope pro 2 trials hub has a smaller casette section so u can only fit 6 gears on! can anyone tell me if they are using 6 working gears on a pro 2 trials hub, tell me what components they are using, can u use a 8spd shifter and 8spd mech but just use 6 of the gears? Edited October 15, 2006 by speedyjustice Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted October 15, 2006 Report Share Posted October 15, 2006 Just get a 6 speed shifter and use the limit screws on the mech. Should work fine as long as your limit screws are long enough. Quote Link to comment Share on other sites More sharing options...
Concussion Posted October 15, 2006 Report Share Posted October 15, 2006 Or..... keep your 8spd shifter, adjust the top/big/high limit screw on your mech leaving the last two clicks redundant! Quote Link to comment Share on other sites More sharing options...
Ali C Posted October 16, 2006 Report Share Posted October 16, 2006 I use a friction shifter, its great as its non indexed so you can fine tune where it goes and get the gears running smoothly, even with a bent hanger.I am using a 9spd xtr mech, any would do.The cassette was the problem area as I think the pro 2 is meant for 9spd spacing, so getting an 8 spd spaced cassette on was difficult......I raided my bikeshops parts bin and found a 7spd cassette which had removable pins, I chose the cogs I wanted and bolted it back together, it works very well. Quote Link to comment Share on other sites More sharing options...
Jamie_Neal Posted October 16, 2006 Report Share Posted October 16, 2006 I had the same problem with running 8spd spacers as it is designed for 6 9spd gears (if that makes sense). I'm currently using 5 8spd gears and 1 9spd gear = 6 gears that work with an 8spd Kool chain.And I'm using a 9spd SRAM gripshift which works OK but it could be better. They do do 6spd ones (cheap).Jamie Quote Link to comment Share on other sites More sharing options...
