will_zooboy! Posted October 14, 2006 Report Share Posted October 14, 2006 Right well my brake is pretty poor at the moment what do you lads use, i use plazmatics pads on a grind it makes a really squeaky noise which is a good thing. it is fairly strong brake but wen i do rails the brake jus slips all the time, so what should i change to??? is a smooth rim better than a grind? Quote Link to comment Share on other sites More sharing options...
max-t Posted October 14, 2006 Report Share Posted October 14, 2006 first of all what rim do you have and how far are your pads from the rim Quote Link to comment Share on other sites More sharing options...
GTF Posted October 14, 2006 Report Share Posted October 14, 2006 Try to land more on top og the rail. I don´t know how you land, but if you land more on top of the rail your brake should slipp less. Quote Link to comment Share on other sites More sharing options...
misson boy Posted October 14, 2006 Report Share Posted October 14, 2006 (edited) Good Brake set up tips:.Make sure the pads hit the rim square and evenly, not on a angle.Clean your rim and a nice fresh grind.Use a boosterand a grind is better for Plaz crm's pads. Edited October 14, 2006 by misson boy Quote Link to comment Share on other sites More sharing options...
flipkickbs Posted October 14, 2006 Report Share Posted October 14, 2006 Good Brake set up tips: .Make sure the pads hit the rim square and evenly, not on a angle .Clean your rim and a nice fresh grind .Use a booster and a grind is better for Plaz crm's pads. Word. It's probably just down to your set-up as opposed to your components. Make sure your brake is bled correctly and doesn't go squishing all over the place. The main thing though as mission boy has said is having the pads meeting the rim square, this will also make the brake feel far more solid. Have a play with it until your happy with it Quote Link to comment Share on other sites More sharing options...
Johneh Posted October 15, 2006 Report Share Posted October 15, 2006 http://www.trials-forum.co.uk/forum/index....showtopic=41481 this may be of help to you Quote Link to comment Share on other sites More sharing options...
will_zooboy! Posted October 16, 2006 Author Report Share Posted October 16, 2006 Right well my pads are square on the rim and the pads are bout 2mm away from the rim plus i use a echo control 4 bolt booster and the brake is perfectly bled, and i have already got tarty bikes to grind my rim twice!!! no i land on top of the rail because i can do it on my mates bike Quote Link to comment Share on other sites More sharing options...
T-OM Posted October 16, 2006 Report Share Posted October 16, 2006 If you have only had one grind get a second as the first one never sticks.hope this helps. Quote Link to comment Share on other sites More sharing options...
bhups Posted October 16, 2006 Report Share Posted October 16, 2006 Tar- A little will do, I run some tar with my plaz and a grind super brake and also i found a light but sharp grind is much better for plaz. Quote Link to comment Share on other sites More sharing options...
gundam Posted October 16, 2006 Report Share Posted October 16, 2006 A hs33 is a good brake and is fine with normal pads if you have a grinded rim as the small grinds bity creates more friction Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted October 16, 2006 Report Share Posted October 16, 2006 Try cleaning the rim. Oven cleaner and warm water often does it for me. Quote Link to comment Share on other sites More sharing options...
