Sucram Posted October 14, 2006 Report Share Posted October 14, 2006 hi ive got the onza musclemans fitted to my t pro and the crank arms came loose so i tighten them up as tight as they will go and it still wobbles, i took the bolt out and wiggled it and it seems as though the sqaure hole has worn down slightly alowing the crank to wobble on the taper. does anyone know what will have caused this and how i can overcome it or will i just have to get new cranks?...many thanks marcus Quote Link to comment Share on other sites More sharing options...
Grizzly Posted October 14, 2006 Report Share Posted October 14, 2006 I think everyone seems to get that after a while. Thats the reason that isis is better i think. As for fixing the problem mabe putting a thin piece of metal just on the inside would help to fill the space. But it will creek like anything! Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted October 14, 2006 Report Share Posted October 14, 2006 I think everyone seems to get that after a while. Thats the reason that isis is better i think. As for fixing the problem mabe putting a thin piece of metal just on the inside would help to fill the space. But it will creek like anything! True, either that or new cranks. For the thin metal use either coke can or similar (Fosters/Stella/heinekken(sp?))good luck, i suggest new cranks and bb for christmas though, maybe tensiles and skf 300? Quote Link to comment Share on other sites More sharing options...
max-t Posted October 14, 2006 Report Share Posted October 14, 2006 (edited) you have rounded the tapers on your cranksunfortunately there is nothing you can do about this as when they start to round they keep going.This would more than likely have been caused by riding with the crank bolts loose.you probably didnt notice.isis is the better option and this style of bottom bracket is partially strongerjust keep riding on your cranks now until christmas , they should hold out till then (if you dont go too big).Ask santa to bring you a skf bottom bracketand a pair of these tensile cranksor if you want a cheaper set of cranks get these echosmax... Edited October 14, 2006 by max-t Quote Link to comment Share on other sites More sharing options...
