TomR Posted October 14, 2006 Report Share Posted October 14, 2006 Right, i've checked the search and FAQ before you say it. I'm gonna get a Minion super tacky and in the FAQ it says a 2.5" fits a base ta26 on a d521, but ive gt a DMR DV which is a fair bit wider. This still gonna fit? ..and is the 2.5" a close fit in the base anyway?Cheers,Tom. Quote Link to comment Share on other sites More sharing options...
Krisboats Posted October 14, 2006 Report Share Posted October 14, 2006 2.35 minion had loads of room and a 2.5 michelin comp 24 fitted fine, essentially the same tyre and tread type as the maxxis. Quote Link to comment Share on other sites More sharing options...
Ali C Posted October 14, 2006 Report Share Posted October 14, 2006 are you sure you want a 2.5"? just with a narrowish rim like a dv you may get a load of tyre fold unless you run high pressure.not saying you should get a 2.3", but have a think about it. Quote Link to comment Share on other sites More sharing options...
GTF Posted October 14, 2006 Report Share Posted October 14, 2006 Ali C got a pont there. If you run the 2.3" the tyre dosent fold as much as the 2.5". Quote Link to comment Share on other sites More sharing options...
TomR Posted October 14, 2006 Author Report Share Posted October 14, 2006 Cheers for the info chaps. Good point on the rim width too, i would get the 2.35 anyway but CRC don't have any in stock which is why i considered the 2.5. Ill go look elsewhere for the 2.3 methinks. Quote Link to comment Share on other sites More sharing options...
GTF Posted October 14, 2006 Report Share Posted October 14, 2006 Tartybikes got them Quote Link to comment Share on other sites More sharing options...
TomR Posted October 14, 2006 Author Report Share Posted October 14, 2006 Cheers for the link. I think my 1.5mm thick nokian DH tube might fit a bit better under one of these than my current 2.1, haha. Quote Link to comment Share on other sites More sharing options...
