1 Speed Or 2?
jackamory
hi, i was just wondering weather any one can help me....if u have a 1 speed bike can u put a crank with 2 chain rings on it and a 1 speed free wheel with a chain tensioner and still swap over crank speeds? any advise appreciated. thanks,
jack
a mech would work alot better then a tensioner cause there designed to take up the extra slack when the chains on the small ring
I can help with this!
I use 2 cogs, my trials gear and a riding gear... What you should do is put what ever trials gear you want closest to the back wheel then use 2 or 3 spacers to have the riding gear a little bit of distance away from the trials gear.
Then using your rear mech single speed it, get the end of a brake cable cut it off and put it through where the cable would go on the mech, then when you need to change gear use the adjusty thing on the back of it to move the mech over... It works awesome!! All my mates have done this and it's so cool to have a riding gear so your not pedaling like a lemon everywhere you go...
thanks ill try it
