rocks370 Posted October 12, 2006 Report Share Posted October 12, 2006 (edited) Hello all,A wile back i bought a Hope Pro II hub (not the trials version). I would of got the trials version but i didnt know it existed when i spent my money .It is the 10mm bolt through verson shown here.The main problems im having with the 10mm blolt throught axel is:1. the 10mm axel i have is only just long enough, both wheel nuts do not cover the entire axel when on the bike.2. I cannot use a single speed tensioner that is held at the wheel bolt (on Pro II trials) or quick release skewers as the axel is too short!I was wondering if theres a way of converting it so i can use the Pro II trials bolts shown here?Is it just as simple as buying Hope Pro2 Trials End Caps or does it need some sought of axel throught it?Regards,Si Edited October 12, 2006 by rocks370 Quote Link to comment Share on other sites More sharing options...
RobinJI Posted October 13, 2006 Report Share Posted October 13, 2006 I'm not sure about converting it to use the pro II trials bolts, But a 10mm axel is a 10mm axel, have a look around and see if you can find an axel for it how it is, just a little longer. Could ask around at your local industrial estate, and see if anyone could make you up an axel by simply cutting off like a 10 * 200mm rod of steel and threading first 30mm of each end. That'd give you pleanty of room for anything you wanted to bolt to the ends. Quote Link to comment Share on other sites More sharing options...
rocks370 Posted October 13, 2006 Author Report Share Posted October 13, 2006 Good idea but wouldn't i have to temper it? (i think thats the correct word - heating it up to different colours that represent different strengths?)Si Quote Link to comment Share on other sites More sharing options...
Krisboats Posted October 13, 2006 Report Share Posted October 13, 2006 Get a ti axle from some crazy company i found on the internet a while back. I cant remember off-hand where it is exactly but it only took me about 10 minutes to google it. They had allsorts of different lengths and sizes so have a look for that. Quote Link to comment Share on other sites More sharing options...
