onza-tpro_whiteindfreewheel Posted October 12, 2006 Report Share Posted October 12, 2006 (edited) what is the most powerful rear pads for the HS33's? where can i buy the heat sink pads or the tarty black pads as i can't find them any where !!! here's a pic of my bike as i am a new member. Edited October 12, 2006 by onza-tpro_whiteindfreewheel Quote Link to comment Share on other sites More sharing options...
yoyoyo Posted October 12, 2006 Report Share Posted October 12, 2006 A. HeatsinkB. The tarty pads were a one off i think, but apparently monsieur Wright has some of the same material or summet. C. You picture of your bike would go in the bike pics thread, if there was a picture.D. Tarty's website/shop, theres some pads on there. Quote Link to comment Share on other sites More sharing options...
max-t Posted October 12, 2006 Report Share Posted October 12, 2006 hi there matewelcome to trials-forum!there are many good brake pads for use with magura hs33 brakes these includeplazmatic crm'skoxx bloxx brownsonza citrusrock pads redrock pads bluemonty 221 xlthese brake pads can be found at tartybikes.co.ukadam and dave really are the best ! if you have a question about the brake pads give them a call ore mail them.they provide great service and help to the trials community top notch shop toothe heatsink pads heasink snowysredsbluescoustsinkscan all be found here at heatsinkbikes.comall of these pads can be mounted into cnc metal backing for extra rigidness and response also.check that site out also max..... Quote Link to comment Share on other sites More sharing options...
onza-tpro_whiteindfreewheel Posted October 12, 2006 Author Report Share Posted October 12, 2006 A. HeatsinkB. The tarty pads were a one off i think, but apparently monsieur Wright has some of the same material or summet. C. You picture of your bike would go in the bike pics thread, if there was a picture.D. Tarty's website/shop, theres some pads on there.thanks i have put a picture of my bike on there now, couldnt get it to work at first !!! hi there matewelcome to trials-forum!there are many good brake pads for use with magura hs33 brakes these includeplazmatic crm'skoxx bloxx brownsonza citrusrock pads redrock pads bluemonty 221 xlthese brake pads can be found at tartybikes.co.ukadam and dave really are the best ! if you have a question about the brake pads give them a call ore mail them.they provide great service and help to the trials community top notch shop toothe heatsink pads heasink snowysredsbluescoustsinkscan all be found here at heatsinkbikes.comall of these pads can be mounted into cnc metal backing for extra rigidness and response also.check that site out also max.....i Have the crm's they're quite good but one of the other people on the forum said the heatsink are better than the plazmatic's? what are the best plazmatic pads to get? picture of my bike working ok now yeah ??? cheer's for you help. Quote Link to comment Share on other sites More sharing options...
Orgun_Donor Posted October 12, 2006 Report Share Posted October 12, 2006 Im running the running the Rock Pad Blues, just bedding them in properly, and they are so far, fantastic!!! Very bike brake, and its getting very loud. Quote Link to comment Share on other sites More sharing options...
onza-tpro_whiteindfreewheel Posted October 12, 2006 Author Report Share Posted October 12, 2006 Im running the running the Rock Pad Blues, just bedding them in properly, and they are so far, fantastic!!! Very bike brake, and its getting very loud.I dont really like the rock pads, my mate has them on his t-mag and i dont think they're as good as the plazmatic CRM's ut he seems to think they are !!! what are the best heat sink pads ? Quote Link to comment Share on other sites More sharing options...
ManxTrialSpaz Posted October 12, 2006 Report Share Posted October 12, 2006 Best name, ever.If you have CRMs already and you think they're crap you probably are missing the one thing that will give you a godly brake. A grind. Get yourself an angle grinder from B&Q, get a metal cutting disc and a nice fine grind across the rim. It will hold beautifully.If you already have/have had a grind and think your brakes are still bad, either regrind, set your brakes up properly or lower your expectations Quote Link to comment Share on other sites More sharing options...
max-t Posted October 12, 2006 Report Share Posted October 12, 2006 to be totally honest mate its best to get a grind if you are going to be riding in the winter in wet conditions.if you dont know what a grind is its this.clickety clickthe purpose of a grind is to make your rim sharp so it increases friction rates when your pad rubs against it.more friction means faster locking and better holding pads and in tuen a satisfied and trusting rider whocan rely on his/her pads.the grind also helps shed water from the rim and makes your brake squeek really loud.do do a grind all you have to do is get an angle grinderturn it on (obviously) then skim it lightly across your rim with the grinding disc about 45 degrees to your rim.drag it along the braking surface nice and lightly and repeat this on both sides until all of the surface is roughthen buy a pair of pads that are meant for wet weather such asrock blueskoxx brownsheatsink red or bluescoustsinkswww.tartybikes.co.uk for the rock and koxxwww.heatsinkbikes.com for the heatsinksmax..... Quote Link to comment Share on other sites More sharing options...
