chasthetrialsrider Posted October 12, 2006 Report Share Posted October 12, 2006 Right i have had my new t-pro 06 frame now for a few eeks and the driveside crank with the freewheel rubs the buttom bracket if i lossen the blt it makes the cranks wiggle any help on what I can do to stop it rubbing and not make it wiggle Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted October 12, 2006 Report Share Posted October 12, 2006 Get a longer bb. 128mm should be perfect. Quote Link to comment Share on other sites More sharing options...
gu_bckearns Posted October 12, 2006 Report Share Posted October 12, 2006 Get a longer bb. 128mm should be perfect.Agreed, maybe go for something like the "try-all" bb if you have ISIS : http://www.tartybikes.co.uk/product.php?id=10or if you have square taper, maybe this : http://www.tartybikes.co.uk/product.php?id=9 Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted October 12, 2006 Report Share Posted October 12, 2006 yep i had this on my old monty you need a longer bb or you could bodge it for the time being by puttin a washer on the bb axle so that the crank arm can go in any further but it will still be tight Quote Link to comment Share on other sites More sharing options...
kfc Posted October 13, 2006 Report Share Posted October 13, 2006 BIKES R RUBISH Quote Link to comment Share on other sites More sharing options...
huge Posted October 13, 2006 Report Share Posted October 13, 2006 (edited) I had the same problem on my 04 t pro using the standard onza square taper cranks.The BB I used to solve this was a shimano un52 with a 68mm shell and a 127.5 axle. Should be about £15 from any bike shop.http://www.chainreactioncycles.com/Models.aspx?ModelID=12hope this helps Edited October 13, 2006 by huge Quote Link to comment Share on other sites More sharing options...
Willsey Posted October 13, 2006 Report Share Posted October 13, 2006 BIKES R RUBISHsimple minded? Quote Link to comment Share on other sites More sharing options...
bowman12 Posted October 13, 2006 Report Share Posted October 13, 2006 BIKES R RUBISHwho is this guy? does he even do trials? ive seen posts from him in a lot of other peoples posts. just slagging them off. someone want to slap him for me???and in response to the post, go isis and get new cranks and a tensile freewheel. after my BB and freewheel fell apart on my 05 t-pro, i changed and ive had no problems since Quote Link to comment Share on other sites More sharing options...
yoyoyo Posted October 13, 2006 Report Share Posted October 13, 2006 who is this guy? does he even do trials? ive seen posts from him in a lot of other peoples posts. just slagging them off. someone want to slap him for me???Just ignore him, he's been banned.Also an example why NMC exists, he spammed an entire page of one forum. Imagine what he would have done if he had the whole forum at his hands.But yeh, you need a new b/b. Just in case you hadn't already realised. Quote Link to comment Share on other sites More sharing options...
trial-biker-ryan Posted October 14, 2006 Report Share Posted October 14, 2006 BIKES R RUBISH tard Quote Link to comment Share on other sites More sharing options...
court Posted October 14, 2006 Report Share Posted October 14, 2006 Hiif you have an acs save your money and just take the crank arm off and grind the remover tabs off that should sort it.But if not just do what every one else has recommended.hope you sort it corut Quote Link to comment Share on other sites More sharing options...
