Shallow Maggie Boosters (to Clear A Ta26)
TomR
What boosters are shallow enough to clear the seattube on a Base TA26? My standard maggie (04 model) one clips it so i can't fit it if my brakes adjusted properly.
Carbon wold be nice, Dunno if Mr Maher's got any carbonique ones kicking about, theyre apparently pretty shallow. The first one i thought of was whitehurst but theyre probably long fizzled out of existence.
My Carbonique 2 bolt booster is 72mm from the line between the hole centres to the top if that helps you. So it's a little smaller than the standard magura one :)
I know there's a carbonique booster knockign around between my mates, Either alan or Bo has it, and I know neither is using it, Could probably arnage something if you wanna PM me. :D
Also The booster that WeeBryan has used on the Vee mounts is indeed a tectro (sorry, not sure if he was saying it 'is' or he thinks it is similar) but I've got a gold one im my shed if you wanted that.
Edited by Dont you Just Hate it When...
I've been talking to Joe about the carbonique boosters, and im pretty sure i've actually got a tektro booster kicking about somewhere, i'm just trying to find all options before i spend any money. Want it to look as neat as possible really, and i think if i used my tektro one it'll look tatty as it aint in great condition.
Looks pretty smart Danny. I want one of those seats again but i think i may need to stuff a bit of seat post down there to reduce the chances of snapping.
Does that flex much? It looks as it'll allow it to flex a bit as the top bolts aren't supported in any way.
