Dvd Burning Help!
Sam Oliver
Hi, Have recently installed a dvd burner, works fine when you copy from disk to disk.
When trying to burn edited video from say, producer or moviemaker it gets to the final
burn procedure & then fails :( any help please quick as it's doin me head in!
Do i need author software?
Cheer's (Y)
Whether you need DVD authoring isn't relevant. If it won't play on a DVD player then you need to start worrying about that, but as you've not even got that far then it's not that.
If it's failing then it's a problem with either the disk or the drive. DVD drives are really funny about which DVDs they'll take and which ones won't work. So you might have incompatible ones. The only thing you can try before getting some new disks is to burn at a slower speed (Y)
