Onza Limey 2
Wright Pads
Was shopping for parts and came acrross this...Mk2 ooo
IPB Image
IPB Image
IPB Image
IPB Image
Description
- Redesigned for 2007, the latest 26" frame from Onza, designed and developed over the course of this season with help from 2005 UK Masters Champion Danny Butler and double 2005 World UCI Champion Ben Slinger, the Limey sits at the top of Onza's range, and is well worthy of doing so!
- The frame features CNC Machined top and bottom yokes, with the BB shell and chainstay yoke being one-piece for maximum stifness. The top yoke also houses the dedicated 4-bolt HS33 mounts.
- Dual-ovalised down tube increases weld contact area at the head tube, while offering a wide join at the BB shell, increasing strength and stiffness.
- Curved and ovalised seat tube resists twisting and bending to create a hugely stiff bottom bracket area, maximising precision and power transfer!
- CNC Machined welded side plates for 2007 stiffen the frame up even more!
- Onza head tube with stainless steel inserts to allow the frame to take a standard 1 1/8" headset, offering the ultimate in strength.
- Even lower standover height has been achieved by welding the top and down tubes together, this also creates a stiffer and stronger front end.
- Classy matt black finish with silver graphics will match your colour scheme, no matter what! (Please note that the colour is still to be finalised, but likely to be matt black)
- 5.5" frame size (centre to centre) and curved top tube for maximum body clearance!
- Weight: Approx 2.03kg/4.47lbs
Geometry
Wheelbase: 1095mm
Chainstay Length: 380mm
BB Rise: 20mm (with Echo Urban fork)
Head Angle: 72 degrees
Centre of BB shell to top centre of head tube: 705mm (27.75")
Additional Information
Limey 2 arriving estimated November
Black is back!
Pete
