Washers On Between The Bashring And Crank
coolbeen
Hi i have just got my crank and freewheel back from the bike shop i they have give me 2 washers do i need both of this washer on or not. i did not have the money for them to fit it to so i am.
The thing is the freewheel does not go down all the way there is a bit of the thread showing still with both of them one.
I have the echo 6061 cranks with the echo 7075 bashring and the freewheel is a tensile.
thanks :-:)
how thick are these washers? in mm? the best thing will to be placing them between the free wheel an bash ring (Y)
The spacer is only to be used if no bash ring is fitted i.e. on a mod bike.
What is the mm and how thick are the washers you have got?
cheers
Luke
