Water Bleed Question
An_toin3
Well I can't stand my magura anymore, always trouble, but no money means I must keep it, so I was wondering if a water bleed would be good !
but you need to consider that I'm from Quebec,canada so automn season here is quite cold, and magura just sucks as always, and having a water bleed, wouldn't it freeze ?
If so, I heard you could put anti-freeze, but how much ? let's say for 150mL you need XmL of anti-freeze ?
Would be nice if someone could help me !
It usually says on the bottle of anti-freeze. The stuff I got said something like:
Down to -5ºC using 10% antifreeze, 90% water.
Down to -10ºC using 20% antifreeze, 80% water.
Just have a read. Although a magura takes only 15-20ml of water so you don't need very much antifreeze at all.
