Help Needed For A Onza T-pro
Right I have just got my new t-pro fram and changed all the parts over from my old bike but the back brake is flexing the frame I have 2 2 bolt boosters 1 for the bottom nuts and 1 for the top bolts I have put the bottom bolts one on but that flexes still what can I do also I cant buy any new parts until next year help me please
thats a bit odd you know. I could still see a little flex in my t-pro with an echo 4 bolt booster but nothing you'd really worry about.
if what's bothering you is a weak brake you could just try better pads(depends what you're running now of course) or just cleaning and setting everything up again.
I'm affraid that theres not really alot you can do about this, I'f after you have both boosters on the frame still flex's then the only solution really, is a different booster thats more effective, but as you said, no more parts until next year. I'm assuming you've checked that it really is the frame flexing, not just a spungy feeling lever caused by a bad bleed?
