bionicman Posted October 5, 2006 Report Share Posted October 5, 2006 i want to buy a new rear rim but i am stuck between a rear viz and a rear try-all any help thanks Quote Link to comment Share on other sites More sharing options...
max-t Posted October 5, 2006 Report Share Posted October 5, 2006 (edited) neither.they are both crap.get an echo 07.they look the same as try all and viz but are better.extra thick sidewalls also so it stands up to denting better and is able to take more grinds.find them on tartymax... Edited October 5, 2006 by max-t Quote Link to comment Share on other sites More sharing options...
Mr Monty Posted October 5, 2006 Report Share Posted October 5, 2006 I agree the new echo rim's are the best choice strong and can hold grinds ( viz rims are very weak). Quote Link to comment Share on other sites More sharing options...
trials 123 Posted October 5, 2006 Report Share Posted October 5, 2006 i would say try-all i have one my self and i have had some harsh landing but neva a dent but viz i have been told that they dent very easy Quote Link to comment Share on other sites More sharing options...
cruiserweight14 Posted October 5, 2006 Report Share Posted October 5, 2006 I got a tryall rim had it 3 months taken everything i've put it through. Quote Link to comment Share on other sites More sharing options...
M3LLON_t-mag Posted October 5, 2006 Report Share Posted October 5, 2006 i run an echo 07 rim they look good and have extra thick side walls and another great thing is they hold their grind amazingly Quote Link to comment Share on other sites More sharing options...
Greeny Posted October 5, 2006 Report Share Posted October 5, 2006 it depend because the new echo 2007 rear rims only come in 32 hole so this means if you a running a rear profile you can not fit the profile to the rim, this is the small problem that i have. so what i did was asked a couple of people and they are advising me to get the try-all rims... (i like the flumo one's personally) because you can get these try-all rims in 32 hole and 36 hole so..if you are running a hub with 32 holes go for the new echo 2007 if not go for the try-all rims which can run 36 hole and 32 holehope this as helped.thank you Greeny Quote Link to comment Share on other sites More sharing options...
Mike Beck Posted October 5, 2006 Report Share Posted October 5, 2006 echo 07 smooth with zoo! pads and maybe a bad of tar. Will be immense and no dents Quote Link to comment Share on other sites More sharing options...
GTF Posted October 5, 2006 Report Share Posted October 5, 2006 echo 07 for sure Quote Link to comment Share on other sites More sharing options...
Ben Beckett Posted October 5, 2006 Report Share Posted October 5, 2006 don't go for the 06 echo, they are really prone to turning into a 50p. , they do have really good side walls but that is about it! the try-all rims seem rather strong in some of the koxx rials videos.....especially TRA'S, i personally wouldn't want a try-all one because i do big stuff and i would probly blow it up in a week so if i was going to get any rim like that it would be the 07 echo because it is more stronger that the last one-e.g the drilled holes are not as wide. but me personally would reccommend getting the onza ronnie, i have used this rim (same one which has had 2 wheel builds) for 9+ months, i have put it through loads and loads of drops, rimmings-i only have a few minor dents on the sidewalls which don't affect the braking what so ever!!, it also doesn't buckle easily but the only downside is that it is 850 odd grams which is a little bit heavier than most rims this is the undrilled version. in my opinion it's the best rim out.i would definitaly reccommend getting this rim (onza ronnie) if you want to ride big and hard, but if you don't then i would say the 07 echo.......damon watson has the 07 echo, and he is a big ridder, and his rim seems fine........i personally haven't ridden one but they do seem very strong.hope you do choose a decent rim bud!! Quote Link to comment Share on other sites More sharing options...
