Tyre Problems
bionicman
why does it rip? are your slave cylinders rubbing against it?
they have really thick sidewalls.
what pressure are you ruinning your tyres at? if its really low the sidewalls would be ripping because of all of the pressure going on them when the tyre folds like every time you hop...
i dont know what else it could be other than the above (N)
max...
Hi,
Maxis are excellent you sure you got the downhill version because you can get a cheeper version with crap sidewalls which will fray really easy?
where you get it from? and how much you pay for it if it was under £20 you probably do have the wrong one (the xc sidewals!!!)
hope this hels.
look at chainreactioncycles.co.uk they have both typs! (Y):-B)
