Longer Frame Short Cranks :(
Mike W
Nothing to worry about. Long cranks are used with long bikes mainly because they don't feel awkward and give you more power. It doesn't mean short cranks will be bad, it just means you've got space for longer ones which imo are better.
okie doke thanks :) il stick with my echos for now then
mike
Hey Dude
I am currently running a Czar 1100 wheelbase with echo 160 cranks using a 17t cog, i am 6'5" tall and am mostly legs, i find them to be great, you seem to have a better balance if your feet are closer together.
I find large gaps and up's the same as i used to when i had 175s
will proberly try a longer crank when these give up or then again.
hope this helps :D
Edited by skuzzbucket
