My Brakes Sponge
zoof
Your not bleeding it correctly then
Wind the TPA all the way off
Lay the bike so the outlet of the leaver is up in the air
Bleed form the bottom slave up
Tap the hose, slaves and leaver as you bleed it
Fit the bolt in the top with the syringe still fitted
Then remove the syring and re fit bolt
If you still have sponge after that i'll eat my own hat (i don't wear hats anymore) as your blantly doing soemthing wrong
Not nessesarily pete, while that one very possible explaination, it could be flex, either from bad setup or lack of booster.
If your pads dont hit the rim sqaure, they will compress more, and if you have no booster your forks are likely to flex.
If your on old style evo mounts, dont use the quick release bit for the booster (unless you really need it) bolt the booster down. Also ensure the plastic elbows are properly against the forks.
EDIT: just noticed, you didnt actually specify your brake, we have just asumed magie rims brake.
If you have a disk, specify which one so we can advise correct bleeding procedure. you may also need to get your disk mounts faced, if ithe caliper is not square over the rotor, that can cause spongyness.
Edited by nmt_oli
