How To Bleed A Hope Mini
trials 123
Do it you self
I bleed form the base up with it off the bike
Take it off the bike
Remove the pads
Fit the leaver clamp in vics as if it was on your bike
Remove top cap
Push pistions all the way back in with a screwdrive and a cloth, carefull of the DOT fuild shooiting out
Now fit soemthing in the pistions to keep them apart, my sons Lego does the job.
I use a syringe with DOT 5.1 and bit of hose on the end that fit over the bleed nipple
Undo the bleed nipple 1/4 of a turn with syringe fitted over
Slowly push down on the syringe to bleed the fulid throuhg
As you do this PUMP on the leaver slolwy
Once bled seal the bleed nipple off
Remove the syringe
Fit top cap
Wipe the brake off
Take it and give it a wash in hot soapy water and give it a good scrubbing
Now fit the pads again
Fit to the bike
It should work spot on and be a better bleed than hope
You can thank me latter
Edit:
opes way, page 9 item 3.3 PDF doc
Edited by Wright Pads
so i just undo that little nipple screw my bleed kit in the same i use to bleed my hs33
put something in clappers then just pump it through untill that little resivor fills up but i took the cap off to day
and the resivor was full i even topped it up an it wa still the same but i didn't pump it but i will give it a go tomorrow thanks for all your help sam (Y):D
Yeah you can use you Magura bleed kit if the hose will fit!
Make sure you syringe full of DOT 5.1 1st and fitted on before you undo the nipple.
You have trapped air in the hose, behind the pistions, in the claiper join, a fubabred seal at claiper or leaver
Bleed it so it over flow the resiovr in the laeaver, so you'll need to put a paper towle there lots of them or a bowle or bucket to ctach it all
i have had a go at it and it is alot better thanks (Y) but i used dot 3 brake fluid and on the to cap 1 of my bolt rounded (N) on it so i don't no what i should do it is tight and working but i cant get it out or anything do he an idea of getting it out and putting a new one in should i send it to hope or something i dont no what to do thanks sam (Y):D
Can you not read!!! Top cap says dot 4 or 5.1 only!!! The manual i posted a link with says it too...
You used a f**ked allen key and over tigthen it!!! They do new top caps with bigger bolts which are tons better, they are on tartybikes
To get that bolt out, hack saw a gove in there and use a thing flat scredriver pushing uber hard dopwn on it and undo it
Do what i said about removing the bolt! Cutting the slot!
Get the new top cap as you wont have this problem again. In fact i might have two leavrs going spear!
I'll do it for you no problems, same day as i get it it'll be done and dispatched back.
Yeah i advise to bleed it again or drain it dry!
Dot 3 is not what hope says to use
Odd i've had water in my Magura for 4+ years still not a problem!!!
Erm, so where do you draw the line?
At least DOT 3 is remotely close to DOT 4 or so, and so is close enough to what Hope use.
Water in a Magura isn't what they say to use...
A little hypocritical there Pete don't you think? :closedeyes:
Do it you self
Remove the pads
Remove top cap
Remove the syringe
Fit top cap
Wipe the brake off
Fit to the bike
Edit:
Out of interest Pete, do you really find bleeding a hope from the bottom up to make much of a difference than the other, more conventional and hope recommended, top down way? Its just i find the conventional way much easier as you do not have to remove the brake, there is much less mess (no fluid coming out the resevoir, just the tube on the nipple) and therefore quicker. i have also never had a problem with it.
Why do you believe it produces a better bleed?
I find form the bottom up, the caliper traps a lot of air so the presure form the bottom get's it out, but i do it both ways. Just find the way i said means less messing about with the niipple going on and off every pump and then tipping in of fuild...all in one, 5 mins and it's done!
True, the one thing that i have noticed is that hope calipers trap a lot of air. Will have to try that sometime.
I am tempted to get the hope bleed kit after using an easy bleed on my car, It pressurises the brake system so you just open the nipple and let it flow till your done, so quick and so easy, plus the extra pressure will help get out stubborn trapped air.
Edited by nmt_oli
I got one but i didn;t like it, i modified it to be used on my Maguras, boiling hot water really does clean them out nicely!
Just changed the hose on there to one smaller to fit a barb, and a control valve on the air so i can control the flow! Just have to pump up the tyre before i use it.
