Help With A Magura..
Greeny
For it was I. Well me er and leeson Bikes many amoons ago.
You need the following okay.
Hope SPORT C2 Leaver (it's the only one that works)
Barbe fitting
o-ring x 2
Fit the barb to the hose
Fit the o-ring to the barb both of them
Fit it to leaver and do up tight, yesht eo-ring will split then need to make a good seal
YOU CAN ONLY RUN WATER, ANYHTING ELES WILL KILL THE HOPR O KILL YOU MAGURA,
MINERAL OIL WHAT SO EVER AMOUNT WILL KILL YOU HOPE SEALS
I got bord of it and found a nice Magura! Fact i still have the leaver. Have add you to msn if you wana chat more dude
Edited by Wright Pads
What a load of bull. Ashton has a deal with Magura for brakes only in 04. The leavers are a lot older than that. 1995!!! Fact it was the 1st leaver hope had made for the 1st disc system.
Clive modified his for his son Kris.
Sorry guys but when you've been around as much as i have and have the contacts i do you'll know everything.
how come you can only use that lever..
you said 'only one that works'
does this mean that its the only hope lever that will work with a magura or do u just think that this particular hope lever is the best and works the best if you get me...
also can you use proper hope oil or royal blood?
also if you can find a picture i would be very grateful
thank you greeny
thank you greeny
The Hope Sport C2 works only due to these reason only
10mm piston, the movemnet and displacemnt this gives is the bear min to make Magura's work. 6mm thats used in a mini leaver will not move them.
C2 is clossed as is a magura, O2 or mini are open and are self adjusting but not for Maguras!
Seals in the slaves will die with Hope fuild which is DOT! Magura mineral oil or any mineral oil will make the Hope seals swell. Water only, it's light, thin, get in the system fully, doesn't kill any seals in ether items.
I'll upload a pic latter if i can find one if not will have to dig the leaver out and get pics. Won't be till after dinenr as i just got in from a wine tasting thing with some mates.
If you do not belive me go ask Clive Leeson and i think Alic did it too. Ashton has never ran this setup.
He did back in the day have C2's on his Canondale with the Sport C2 leaver!
Piston doesn;t move as much and doesn;t give the same amount of displacement thats needed.
Think it's also got smaller piston i think but it's mainly due to the displacement and the way the fittings are!
Clive tried it.
Though i have found a way cool mod for the Pro C2 leaver so im hunting a set of them down asap...not for magura use
wowwwwwwwwwwwww......u really must know everything..you are god :o
I been in the MTB screen for years and years, Hope is owned by family, EBC is family run, I help Clive Leeson out and vice versa, use to get MBUK till they went gay and that had good info back in the day, TF use to be a good sorce of info form many memmebers but died now and i've experimented and am a fully qualifed park tool and act aproved trianed mechanic so i know my stuff
ok thanks a lot guys and right pads seem's to know what he is on about so...
wright pads could you get me a list of places were i could get all the stuff from to build this break.?
also thank you everyone else
i'm also interested to know what others think or if they have a better idea i'm hopefully going to have a braided bridge as well on rear cylinders
thank you all again
Greeny
Add me to msn or e-mail me dude. pjalchemist@aol.com
I would highly recomend a hope braded hose kit off Tartybikes, it would work perfectly with it, in fact i'd say in all honestly it's all you should use. if you were to use said leaver make sure you tell tarty what fitting you need to go in the Hope leaver
what i would do is i would get all the stuff and send it all of to tarty and get them to build it me up. i don't think i would get all braided as it is a lot of money so i thought about just the bridge.
but thank you anyway
Greeny
Greeny
the thing is, the hope hose makes it much easier to connect to the lever end as you can get the hope fitting. magura hose is thinner than hope hose, so doesnt work as well, although std hope hose is IMO better than maggie hose, braided best off all.
Issue that lies with Danny and Tom from about 4 years ago when the forum had just come out kinda thing.
Something over time has way too many people stick there nise into and make storys up form and what not.
Too many storys about things to thing i haven't done which can be proven very easyerly.
Tom and Danny have never aproached me to resovle any of it.
I did meet Tom i think it was or maybe John once @ DJ ride directly after his funeral and was told it'd be all sorted and put back but thats what nearly 3 years on!
Ah well celave
