Geared Mod
As Adam said above Mod's have a f**ked up gear ratio so the range to fit on the back aint gonna happen.
Also there is 110mm spacing and for gears 135 is needed really. Admiterly leeson have made a mod that runs a std MTB being 135mm spacing.
It's not gonna happen.
Oh and a mech can be fitted to a mod but it's tensioning the chain thats all
Considering most mods have a 18t or smaller front gear, and the smallest rear cog you can run is about 12t,
that isnt going to give a much more practical ratio...
Run a real bike if you want something to get around on.
Im preety sure his point is not that he wants gears to ride to the shops, more likely that to actually get to spots to ride it is sometimes is abit of a treck.
Im not going to comment on the actual topic because I knoww nothing about mods. :)
Phil
bionicman and you fellow anyoing friend
GO READ THE THE FORUM RULES PLEASE
READ THT TOPIC YOUR WANTING TO POST IN BEFOR YOU POST YOU 99% POINTLESS REPLYS IN PLEASE AS YOU RE DOING NOWT BUT SPAMING THE FOUM ONE AFTER EACH OTHER AKA AS IF YOUR JOINED AT THE HIP BUT VIA YOUR MALE TOOLS
GIVE IT UP
GIVE IT UP
Why are you telling people the rules. If you obey to them, you might be validated by now.
the new leeson mod is it posible to run gears on one of them perhaps you could ask clive to make on specialy for you and run 22 t up front and 16 as you trials gear and 12 as your "getting about gear"plus you could run a pro 2 or a normal chris king
